Team Associated TC6 Thread >
Like Tree20Likes
Old 02-03-2011, 02:12 PM
  #1681
Buckaroo's Avatar
Originally Posted by Paul Ohlsen
Is there place where I can get the bulkheads at?
Thanks.
Right now your best bet is calling Associated direct.
Buckaroo is offline
Old 02-03-2011, 03:37 PM
  #1682
muststopcrashin's Avatar
I'M geting well pissed off at the moment in the uk, i can't get any of the parts i need...........
to sort my cars set up out, it is mad that i pay 380 for a car, and then need to replace parts to set it up, away from standard, and after that i have to wait 3/4 weeks for them. i want a cva rebuild kit so far 2 weeks.........................and that just a start. anyone know why??????????????
at the moment i wish i had an xray..............
muststopcrashin is offline
Old 02-03-2011, 04:32 PM
  #1683
Paul Ohlsen's Avatar
Paul Ohlsen is offline
Old 02-03-2011, 07:40 PM
  #1684
AeRacer805's Avatar
Has anyone tired a Protoform P-37 body yet on a TC6 I just mounted and painted one up. I have an LTRC as back up but would like to try the P-37.
AeRacer805 is offline
Old 02-03-2011, 07:56 PM
  #1685
kschu's Avatar
Trader Rating: 16 (100%+)
p37 good for hairpin corner...
kschu is offline
Old 02-04-2011, 02:03 AM
  #1686
daleburr's Avatar
I'm surprised you feel the need to buy additional parts to change the setup. The only parts I've changed are the shock springs to something a bit stiffer (the kit ones are okay if grip is very low). Even the team drivers only change the springs and fit a stiffer front roll-bar (which Demon have got in stock). What handling issues are you having, and what surface do you race on?
If you're struggling for spares because you've broken stuff, then AMain have got most stuff in stock, which will take a couple of weeks to the UK. Not ideal, but better than waiting a month:
http://www.amainhobbies.com/advanced...=TC6++&x=0&y=0
daleburr is offline
Old 02-04-2011, 03:27 AM
  #1687
Default HB DCJ shaft
Anyway, HB dcj shaft fit with no issues, only need hex
and pin from HB and 2x 5x10x3 bearing, maybe 5mm thin spacer
beetwen pin and hearing.
But DCJ is a little too short. I like 2mm spacers under a-arm mounts, and pin in bone is on the limit.
Also pin is a little bigger then AE/Y and need bigger hole in plastic to put it into diff/slipper spool.
Also I saw used DCJ shafts at front in cyclone, and ...they also don't last long.
Compared to price 33$ per 1 piece, it is not worth.
Maybe Litlemodz will be the best choice
Regards!
m.
M.Abramowicz is offline
Old 02-04-2011, 03:51 AM
  #1688
daleburr's Avatar
Regards!
m.
I think the kit steel driveshafts are the best choice. Additional cost = $0. If they're good enough for the team drivers who TQ and win national events, they're good enough for me!
If you're getting a lot of chatter, try going for a setup that gives the car more front end grip, then reduce the steering lock. I run at about 60% lock (with 100% being on the lock stops).
daleburr is offline
Old 02-04-2011, 05:29 AM
  #1689
Default Heads Up
Just for everybody in the UK, CML and the Team Associated lads are having a workshop at Ardent Race Track, Derbyshire. All TC4/5/6 drivers welcome. Book early to avoid disappointment
Check out the CML website.
cmldistribution.co.uk
Should be an interesting day
David
xrayracer2 is offline
Old 02-04-2011, 08:27 AM
  #1690
Jimmy Avila's Avatar
Trader Rating: 81 (100%+)
Can anyone tell me what size locknut comes on the wheels of the tc5? I was thinking it was 5mm but wanted to double check. please pm me the answer. Thanks for the help!
Jimmy Avila is offline
Old 02-04-2011, 08:30 AM
  #1691
Nevermind. I looked up the exploded view. its 4mm
Old 02-04-2011, 08:35 AM
  #1692
jag88's Avatar
not ALL the team drivers use kit shafts.
jag88 is offline
Old 02-04-2011, 09:10 AM
  #1693
forrestboy's Avatar
will the xray shock springs work on the tc6 or are they different sizes?
forrestboy is offline
Old 02-04-2011, 11:08 AM
  #1694
Trader Rating: 18 (100%+)
Default How do you use Battery Straps on TC6
I'm buying this car in the coming week and wonder how you mount the velcro straps I saw in one post. Is there some kind of hook on the chassis that the strap goes through?
lyrragnus is offline
Old 02-04-2011, 01:41 PM
  #1695
Buckaroo's Avatar
Yes, the hooks that hold the battery in also have tabs that are normally used for tape. Simply slip the velcro strap through. I recommend the Top from the Photon, works perfectly and doesn't go under the batery.
Buckaroo is offline
