Old 05-27-2004, 08:27 AM   #1
Default tire wear question?
Im running rubber tires on an asphalt track. Im getting a lip on the inside of both front tires. And lastnight it wore all the way thru the rubber. Why am I getting this? Is something set wrong like the chamber?
stumper is offline   Reply With Quote
Old 05-27-2004, 08:32 AM   #2
sosidge's Avatar
I would say the insert isn't wide enough for the tyre, and/or it's too soft for the conditions.
Old 05-27-2004, 08:37 AM   #3
So probably some harder inserts? That makes sense.
Old 05-27-2004, 08:43 AM   #4
Send a message via ICQ to Cobra81li200
I had the same with sorex tires. I solved it by using thicker inserts (like the sorex A instead of B).
Cobra81li200 is offline   Reply With Quote
Old 05-27-2004, 09:09 AM   #5
Wency_TA03R-PRO's Avatar
I say get a medium insert for your tire and make sure its a perfect fit inside of the tire before sliding the rim....
Wency_TA03R-PRO is offline   Reply With Quote
Old 05-27-2004, 09:12 AM   #6
The insert is too thin and because of that the rubber is rolling over onto the bead when you corner.
James Nguyen is offline   Reply With Quote
Old 05-27-2004, 09:13 AM   #7
I think the tires Im using have another brands insert. So I take it from now on to use the same brand as the tire.
Old 05-27-2004, 09:27 AM   #8
Just want to ask what brand of tire are you using? are you racing or just bashing around the parking lot??..
Old 05-27-2004, 09:37 AM   #9
sorex and im racing 19t with a losi xxx-s and Evo III
Old 05-27-2004, 10:01 AM   #10
JoshR 85's Avatar
HeY!!!
I heard that the Takeoff's aint bad (takeoff 32's i think) i don't know i never raced asphalt, thats what i beleave i heard...
JoshR 85 is offline   Reply With Quote
Old 05-27-2004, 10:09 AM   #11
Exclamation
Get a sorex 36R match with medium insert. It runs great on asphalt race track..
Old 05-27-2004, 10:26 AM   #12
Charlie O's Avatar
If they are wearing on the inside then you have to much negative camber, if there wearing on the outside not enough, or to soft of an insert.
Charlie O is offline   Reply With Quote
Reducing Tire Wear Riketsu Nitro On-Road 28 02-08-2008 10:36 PM
Funky tire wear... JEMCIV Electric On-Road 26 05-21-2007 06:59 AM
Tire wear RKeasler Electric On-Road 1 09-02-2006 06:30 PM
Rubber tire wear Question Ridge_Racer Rookie Zone 4 12-15-2005 12:45 PM
Tire wear question R_Andersen Electric On-Road 4 03-26-2002 11:19 AM
