xray shock miseries >
xray shock miseries
xray shock miseries
Old 05-27-2004, 12:50 AM
evaa's Avatar
Default xray shock miseries
xray owners, i know you all have had miseries while building the shocks, especially when it cam time to screw on the eyelets. can u share your experiences and how you cope up with them? or even better, how you solved them?
evaa is offline
Old 05-27-2004, 01:28 AM
Soviet's Avatar
A cure for your ills my friend...
Soviet is offline
Old 05-27-2004, 01:34 AM
fatdoggy's Avatar
C'mon this really is sad. I've been running the serpent adjustable shocks(almost the same) for ages now and they are easy to rebuild and nice and smooth. If you really don't like them move to tamiya flurine coated units and never look back.
fatdoggy is offline
Old 05-27-2004, 01:48 AM
evaa's Avatar
i know how easy it is to screw on serpent eyelets, broke a couple of them while screwing them on my xray
if you will read the post, in fact if you will go to my previous posts in the xray thread, ull see how i love the car, its just that in the other thread regarding the setting of camber, the building of xray shocks became a but of jokes, that's the reason why i started this thread.
by the way, have u tried the xray shcoks urself? hope ur also speaking from experience as regards xray shocks
evaa is offline
Old 05-27-2004, 02:31 AM
I must admit I cheated with my FK shocks... I took the alloy ones from my TC3 along with the fittings...
Perfect!
TraceRacing is offline
Old 05-27-2004, 03:13 AM
dtm
dtm's Avatar
Pre-thread the eyelets with a 3mm screw before you put the shaft in. They are a b*tch to get on but once they are there I've had no problems....they are worth the initial pain!!!
dtm is offline
AdR|aN's Avatar
Default Re: xray shock miseries
Hiya evaa.
This is what i do.
I use a cutter plier and hole it on to the threaded end.
Hold it at the finishing thread and not at the start of the thread.
Hold it tight and try to turn the eyelet in.
Once the eyelet is in a little, use a plier covered with cloth and grab the eyelet.
Keep turning the eyelet till it meets up with your cutter.
P/s : Use a small cutter. A bigger cutter and you will actually cut off the shaft.
Hope it helps
AdR|aN is offline
Old 05-27-2004, 03:15 AM
dtm
dtm's Avatar
Oh yes....if you pre-thread...make sure you clamp the eyelet with a nice large mole grip or vice!!
dtm is offline
Old 05-27-2004, 08:19 AM
fatdoggy's Avatar
So which are easier to get on, the serpent or the Xray eyelets? I've used the serpent and schumacher eyelets and both required 2 pairs of pliers one on the shaft and the other on the eyelet to screw them on completely. Hence why I doubt the xray eyelets are any harder to get on... I may be wrong though...
Time + Patience = Problem solved.
fatdoggy is offline
Old 05-27-2004, 08:25 AM
rayhuang's Avatar
The problem with using side-cuts is it causes a stress riser and the shock can snap there as Serpent shock shafts are among the hardest-but most brittle. Thats not to say you shouldnt use side-cuts-just be aware of the problem that causes. The leather trick is about the best. I also have a pair of bigger needle nose pliers that I grinded smooth and I often use them to hold shock shafts. MInd you I have to hold on twice as hard.
rayhuang is offline
Old 05-27-2004, 09:55 AM
Soviet's Avatar
Ahem...
http://www.rctech.net/forum/attachme...&postid=903003
Soviet is offline
Old 05-27-2004, 09:57 AM
rayhuang's Avatar
My comment was in reference to your pic there buddy boy!!!
rayhuang is offline
Old 05-27-2004, 09:58 AM
I made a little shock tool that works great.I took a piece of 5/8" diameter brass and cut it 1/8 of an inch thick.Milled a slot to the center that will slide over the shaft.All i do is grip that with a regular pair of pliers and no slipping,no marks on the shaft.Works great on all shocks.
GRIZZLY-A is offline
Old 05-27-2004, 10:17 AM
rayhuang's Avatar
Dont take your eyes off your toolbox when I am around Grizzly-A!!
rayhuang is offline
Old 05-27-2004, 12:39 PM
Soviet's Avatar
I actually was meaning that for Fatdoggy...
Soviet is offline
