Foam wheel for WGT car?? >
Old 07-06-2010, 02:22 AM
tudor_47's Avatar
Questions?? Foam wheel for WGT car??
Hi
This has probably been asked a million times..
I am in the market for som new wheels for my WGT (XRAY X10 link).
I have now the wgt spec wheels from BSR(lilac?) and I want a set of wheels with more grip in the rear.
I have found the xceed line of wgt wheels but I do not know how to choose..
pink, double pink and so on...
I have been searching and I think the the pink is the softest compound. So if I put them on in the back should I go for pink for the front too???
Also if there is a list that shows what shore the different color represent that would come in handy too.
Thanks!
Background we run outdoor on asphalt with no tire additive and no surface prep. We run 2cell lipo with 5,5T motors.
tudor_47 is offline
Old 07-06-2010, 10:26 AM
Capt'N_Slow's Avatar
Check out this site for more information on 10th scale foams.
http://www.johnsbsrracing.com/foam/10thscale.html
Asphalt setup sheet: Give these ideas a try
http://www.rctech.net/forum/5998907-post902.html
Capt'N_Slow is offline
Old 07-06-2010, 12:32 PM
tudor_47's Avatar
Thanks!
tudor_47 is offline
Old 07-06-2010, 12:43 PM
Make sure you check with whoever is running the race...WGT classes usually use a spec tire and don't allow you to use anything else.
InspGadgt is offline
Old 07-06-2010, 02:13 PM
We don't run a spec tire for WGT in our series (FSEARA). Most people here run Purple fronts and pink rears.
BullFrog is offline
Old 07-06-2010, 02:33 PM
tudor_47's Avatar
oh, we do not have a class at our track as we are to few... I only need to find what to use to get a good running car... on asphalt
maybe purple front and pink rears is a good place to start?
tudor_47 is offline
superspeed's Avatar
purple - front
pink/gray - rear
They (local tracks across the country) need to bring F1 back, open wheel racing is pretty exciting.
superspeed is offline
Old 07-06-2010, 04:17 PM
F1 died many years ago around here. Still have my Tamiya F1 for the 1990's hanging on the wall.
BullFrog is offline
Old 07-06-2010, 06:43 PM
tallyrc's Avatar
pink and purple is good, remember to sauce them rears if traction is real bad... and get the tack clean
tallyrc is offline
Old 07-06-2010, 07:48 PM
el salvador's Avatar
Exclamation Can you say "Hand-Full"?
Are you not allowed to use any Tire Additive?
And if not, you might consider going to a 10.5 or even 13.5 Motor and the heaviest (as in weight) 2s LiPo battery you can fit in your car. With that much Horsepower and no Tire sauce, diff adjustment and uniform/equal Rear Tire Diameter, along with basic setup will be critical.
Maybe John Stranahan will "Chime In"?
el salvador is offline
Old 07-07-2010, 01:36 AM
tudor_47's Avatar
Nope Not allowed to use tire additives nor is the track beeing prepped with anything except rain... and what else nature will provide...
tudor_47 is offline
Old 07-08-2010, 04:23 PM
tallyrc's Avatar
ahh that changes things.. add lead.. lots of lead.. seriously, like 5+ ounces with that motor.. suntan lotion isn't officially sauce. claim you were usinig it on your hands and it got on the tires.. the white creamy stuff.. not the spray on crap. i use banana boat kids 50 spf..
tallyrc is offline
Old 07-08-2010, 06:05 PM
That's a good idea. OR if the sell Goop (a hand cleaner) without pumice. All this does is clean the tires. You put it on and take it right off. The towel will be black with dirt.you can even use this indoors on carpet.
BullFrog is offline
