Old 07-03-2010, 10:04 PM   #1
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default Timing Loop Bridge
I searched though here recently looking for info on making a timing loop bridge. I found a little information but it wasn't much. I figured I would post what I ended up with.
Cost was 25-30 bucks. We are hoping to use this on an indoor carpet track. The plan is to use 4 straps to attach the loop legs to the tops of the boards so the loop doesn't interfere with the racing surface at all.
Old 07-04-2010, 06:27 AM   #2
Nice job, I did a similar one for my mini-z track with a different style of top bow. I also walled in the ends with plastic "cardboard" as my I Lap was picking up cars next lane over on certain track layouts.
http://www.youtube.com/watch?v=DBtLY...eature=channel
"we need to do at least 11.2 km/s to break earths orbit or almost the speed as Cam's car"
Neil Armstrong 1968
Cammer is offline   Reply With Quote
Old 07-04-2010, 08:02 PM   #3
FREAKAH's Avatar
Jeez, at least you could give me some credit.
http://www.rctech.net/forum/7592367-post17.html
http://www.rctech.net/forum/7592544-post18.html
http://www.rctech.net/forum/7594758-post19.html
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-06-2010, 11:20 PM   #4
Sorry. I wasn't trying to offend. Thank you for your help!
Old 07-07-2010, 10:06 AM   #5
The bridge in the pic is a good idea. I would make 2 changes, 1 make it lower to where there is just 3 to 4 inches of clearance, and 2 make sure the width of the loop is at least a minimum of 18 inches apart. Other than that good job.
Dave Irrgang
Diffdude is offline   Reply With Quote
Old 07-07-2010, 10:38 AM   #6
We have since shortened it to about 14 inches from the track surface. If I can't get the loop to read I may increase the width. Thanks for the ideas.
Old 07-07-2010, 11:12 AM   #7
Heres some more info
http://www.rctech.net/forum/7638119-post20.html
http://www.rctech.net/forum/7638165-post21.html
http://www.rctech.net/forum/7638283-post22.html
Old 07-07-2010, 04:31 PM   #8
SWTour's Avatar
Is your carpet permanent?
For carpet I generally use 24ga "Speaker Wire" and Gorilla Tape, and put the loop right where I want it on the tracks surface.
(I do the same thing on ASPHALT and CONCRETE Tracks outdoors as well) - on everything from 100ft Bull Ring tracks to a 820 ft High Banked VELODROME
The benefit of NO BRIDGE - No mess, no tearing it down, No Storage, and NOTHING to obstruct view or crash in to.
The bad part - a roll of 24ga Speaker Wire (75 ft long) from Radio Shack is about $5.00 and a roll of Gorilla Tape at Wal-Mart is about $9.00 - and I use a FRESH LOOP for every race.
The speaker wire has w strands (I use solid core wire when ever possible) and is thin and flat, so it produces almost NO bump at all.
I've never used a Resistor inline in the wire either (AMB usually recommends one) but I've never done it in 14 years of setting up races)
The width of the loop, I generally make 12-14 inches, but have done them as narrow as 8 inches, and as wide as 18. (I did a bridge for a few events, and ALWAYS had issues when using it, and it was only about 12" inches high.)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 07-07-2010, 09:02 PM   #9
Permanent carpet. We actually have a loop already under the carpet, but we are shifting where we race on the carpet to another section. We have 60' X 100' of carpet and are going to start racing on a section thats 40' X 75' that is farther from the indoor off-road track that we share the building with. The new section also doesn't have any poles in it. Were using a bridge for now to evaluate our options.
I tested a few things and eliminated the RG-6 coax I was using to extend. With just RG-59 between the decoder and the loop I was able to get the bridge to work. Now I just need to test adding more RG-59. Thanks for the ideas. If things work out we may just cut a slit in the carpet and lay wires like you suggested and then glue the carpet back down over it. I'll try to post whatever I learn through the course of this.
So far it looks like its important to use only RG-59 between the decoder and the connection box. I also believe the resistor is not necessary.
Old 07-12-2010, 09:56 PM   #10
It turned out that the problem was the quantity/quality of connections we had in line between the decoder and the loop. I ran a fresh 250' line of RG-6 straight from the decoder to the loop and it works awesome now. In fact I can raise the loop another foot or two and still get good reception. Bottom line is use RG-6 or RG-59 and use up to 100 meters (~330 ') with no connectors. Perfect reception!!
Old 07-13-2010, 12:12 AM   #11
For carpet I generally use 24ga "Speaker Wire" and Gorilla Tape, and put the loop right where I want it on the tracks surface. (I do the same thing on ASPHALT and CONCRETE Tracks outdoors as well) - on everything from 100ft Bull Ring tracks to a 820 ft High Banked VELODROMEThe benefit of NO BRIDGE - No mess, no tearing it down, No Storage, and NOTHING to obstruct view or crash in to.The bad part - a roll of 24ga Speaker Wire (75 ft long) from Radio Shack is about $5.00 and a roll of Gorilla Tape at Wal-Mart is about $9.00 - and I use a FRESH LOOP for every race. The speaker wire has w strands (I use solid core wire when ever possible) and is thin and flat, so it produces almost NO bump at all.I've never used a Resistor inline in the wire either (AMB usually recommends one) but I've never done it in 14 years of setting up races) The width of the loop, I generally make 12-14 inches, but have done them as narrow as 8 inches, and as wide as 18. (I did a bridge for a few events, and ALWAYS had issues when using it, and it was only about 12" inches high.) It turned out that the problem was the quantity/quality of connections we had in line between the decoder and the loop. I ran a fresh 250' line of RG-6 straight from the decoder to the loop and it works awesome now. In fact I can raise the loop another foot or two and still get good reception. Bottom line is use RG-6 or RG-59 and use up to 100 meters (~330 ') with no connectors. Perfect reception!!
lehua768 is offline   Reply With Quote
Old 08-14-2010, 02:21 AM   #12
Still sorting this out. Were currently using the 24gauge wire with gorilla tape. We have a permanent facility that gets used during store hours 7 days a week. With no supervision on the track lots can happen with all kinds of on and of road cars finding their way ontot the carpet. I have come to the track to practice during the week and found the loop untaped, broken, moved etc 3 or 4 times in the last 2 months. I'd still like to get the bridge to work.
Does anyone know of or race at a track that uses a bridge with the ANALOG (big box with screws at four corners) connection box? I am starting to wonder if the problem with the signal strength is the old box were using. All the bridge tracks I have sen are using the new small black epoxied connection box.
I-Lap Timing system Jochim_18 Radio and Electronics 94 08-16-2017 12:59 PM
Lap Timing Systems yyhayyim Electric On-Road 113 07-25-2014 01:08 AM
Timing loop bridges FWR Racing Forum 6 09-17-2005 12:08 AM
AMB Timing loop JimMcClure Electric On-Road 14 10-05-2004 04:35 PM
