Reedy fan attached to heatsink at tower hobbies >
Old 05-25-2004, 03:26 PM
Nova F1 Racer's Avatar
Default Reedy fan attached to heatsink at tower hobbies
http://www2.towerhobbies.com/cgi-bin...?&I=LXHAZ7&P=7
Cute.... but will it work?
Nova F1 Racer is offline
Old 05-25-2004, 03:33 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
it works, I have one and it really brings the temp down. Only thing is I may have to sell as I don't know if it will fit in my buggy yet.
Cain is offline
Old 05-25-2004, 03:40 PM
JDXray's Avatar
i really want to get one, they look cool and bring down the temperature in the motors, i hear it is handy to have.
JDXray is offline
Old 05-25-2004, 09:01 PM
Tech Legend
Cain's Avatar
You can't go wrong with them. They really work. I was really suprised by the difference it made.
Cain is offline
Old 05-26-2004, 08:39 AM
JDXray,
Do you know if the Associated cooling fan and fin fit in the Xray....?
vadn1 is offline
Old 05-26-2004, 08:57 AM
Wency_TA03R-PRO's Avatar
Yup! it sure does lower the temps on the motor easily due to force convection (w/ the use of fan). This is really a one cool innovation although the priciple is just a simple as that right guys?..
Wency_TA03R-PRO is offline
Old 05-26-2004, 09:05 AM
Sleighty's Avatar
yer sure if you like using re-circulated hot air
get yourself a Ride air duct, simply a piece of lexan attached to your car which directs fresh air into the car while it is on the move much better & much cheaper
Sleighty is offline
Old 05-26-2004, 09:42 AM
Gutter Ball's Avatar
Mine worked when it stayed on. The fan they use is pretty cheap though. There are 2 other guys that had them and their fans are broken (fins breaking, outer edge cracking).
Mine is totaly toast, fellow racer said "you gotta bend them a bit to make them fit snug" so he proceeded to bend it and then snap my heatsink and fan in half
Gutter Ball is offline
Old 05-26-2004, 09:54 AM
Anyway how much does it cost you?.
Old 05-26-2004, 10:11 AM
AdR|aN's Avatar
Originally posted by vadn1
JDXray,
vadn1. The cooling fan w/fins cannot be used on the XRAY.
XRAY cars have problems attaching fins to the motor due to the nature of not having enough rooms to do it.
I would suggest getting a similar fan only and stick it to your chassis while blowing your motor.
Hope it helps.
AdR|aN is offline
