Serpent S401
Old 07-01-2010, 10:08 AM
  #16
RevMaxx's Avatar
Originally Posted by Pablo Diablo View Post
With very thick oil it would give better off power steering compaired to a spool and not diff out like a loose diff on power. I have run something similar and in certain situations is fast.
do diff weigh slightly heavier than solid/spool?
RevMaxx is offline
Old 07-01-2010, 10:20 AM
  #17
wstuart's Avatar
Trader Rating: 117 (98%+)
Yeah with the oil in there they do a little bit. It helps a little if you pull 2 of the gears out though
wstuart is offline
Old 07-01-2010, 10:48 AM
  #18
Pablo Diablo's Avatar
Even if you pull 2 bevels out it will be more than a spool. Probably twice the weight if not more. In mod that weight won't be that big a deal. Looks like spools are the fastest at the world anyway.
Pablo Diablo is offline
Old 07-01-2010, 10:53 AM
  #19
RC MARKET's Avatar
Front & Rear gear diff !
RC MARKET is offline
Old 07-01-2010, 11:17 AM
  #20
corallyman's Avatar
Trader Rating: 101 (100%+)
Look at the rear sway bar mount, that's pretty cool right there. Also regarding the double gear diffs, remember when Serpent first introduced the rear gear diff, alot of people thought it wasn't needed and not an advantage, now they are pretty common.
Steve
corallyman is offline
Old 07-01-2010, 02:56 PM
  #21
TimPotter's Avatar
Trader Rating: 14 (100%+)
New shocks ?
Please drill holes in the chassis so the Tamiya split blocks can be used.... Or Serpent ones can be developed...
TimPotter is offline
Old 07-01-2010, 03:26 PM
  #22
JayBee's Avatar
Trader Rating: 31 (100%+)
This car looks very interesting.....and I'm definitely interested!!
JayBee is offline
Old 07-01-2010, 07:31 PM
  #23
RevMaxx's Avatar
for new cars that are coming out, it would be really nice if they can put in double joint CVDs in the front as stock part. its a must have part...
RevMaxx is offline
Old 07-01-2010, 07:57 PM
  #24
venom54's Avatar
Default S401 OR S410
Looks like I'll have another car on the shopping list when they are available.
Cheers
Ren
venom54 is offline
Old 07-01-2010, 10:53 PM
  #25
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Cammer View Post
Looks like an X Ray spur and Ackerman adjuster.
And a T3 top deck
BlackedOutREVO is offline
Old 07-01-2010, 11:05 PM
  #26
JayBee's Avatar
Most of the new top decks out look the same. No biggie
JayBee is offline
Old 07-05-2010, 10:59 PM
  #27
Racer Z's Avatar
Can't wait to get mine!!
Racer Z is offline
Old 07-05-2010, 11:55 PM
  #28
JayBee's Avatar
This is my next touring car
JayBee is offline
Old 07-06-2010, 09:11 AM
  #29
KweetNiet's Avatar
Looks like they've fitted the 733 light weight diffs in this car.
KweetNiet is offline
Old 07-06-2010, 10:02 AM
  #30
Looking over the car it has all the key components to be fast and is a small improvement to some of the top TC's in some areas. I would be surprised if it wasn't fast out of the box. If I was to change my current TC this would be my top choice.
The gear diff has always been better than the ball diff as far as I am concerned but the trouble is due to the higher weight and lesser motor power in years gone by they had some disadvantages too. Now with brushless torque the weight is almost a non factor. If you have ever run a diff up front you know how much better your car is around corners but with a gear diff you can get the same action with out the lack of drive or brakes while turning. The gear diff was always better its just now that TC companies are looking for every improvement that they have revisited this tech.
Dragonfire is offline
