Old 02-06-2012, 03:39 PM   #91
wingman2's Avatar
Originally Posted by sidecarphil1 View Post
Ordered my new rear end today , it should arrive tomorrow then cut some tyres down and off racing sunday i hope ;-)
The Thunderpower motor has some power
looking forward to learning to drive a WGT car
Awesome mate, with my 1c/10.5 setup, the car is really easy to drive as there is far more grip than there is power. You can concentrate on your lines and consistant laps. Looking forward to Ardent at the of the month, its gonna be great!
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 02-06-2012, 06:28 PM   #92
Yes that was me. And I was pitting right next to the Munno's. And I remember you at TQ with your 1/12th. It's been awhile since I've driven anything but a Corally.I even won the ROAR Masters 1/12th in 2003 with a Corally .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-07-2012, 12:20 PM   #93
wingman2's Avatar
Nice one
Old 02-07-2012, 02:28 PM   #94
New rear end fitted and looking forward to testing it out soon
Feels really smooth and it allows the battery to be fitted all the way to the rear
sidecarphil1 is offline   Reply With Quote
Old 02-15-2012, 03:30 AM   #95
corally's Avatar
Default REAR POD
Hello
wath part number for this option? i try to searchon Corally site but no found..
Originally Posted by wingman2 View Post
Test fitted the new rear end parts to the car last night, here are some pics:
The new 4-pivot rear end uses a pod plate that provides the forward to back movement, whilst another plate takes care of the left to right movement. Everything is nice and free with no binding!
Will now take the parts off the car and give them to my mate to do the supergluing and sealing (which he does the best I have ever seen!). Will test in a week or two and let you know what happens!
As for the servo, I played around with the placement and found that bolting it to the back of the mounts gives the best ackerman angle plus the best bump steer angle for the turnbuckles.
Feel free to ask any questions or if you need a specific pic of something on the car.
Cheers, Chris.
corally is offline   Reply With Quote
Old 02-15-2012, 12:18 PM   #96
wingman2's Avatar
Hi there, the P-4 Coversion Kit is part #: 74790.
If you go to corally.com , then click on the pretty girl, the latest catalouge appears which has the P-4 parts at the bottom left of the left hand page.
I tried my car out last night with the new rear end parts and was very impressed with the handling. I will try some softer side springs to see how that helps (or not!).
Cheers,
Chris.
Old 02-15-2012, 02:16 PM   #97
I got my body painted up
looking forward to driving it , but 1st need to finish my new house ;-(
Old 02-16-2012, 03:00 AM   #98
corally's Avatar
Thanks wingman
use a short battery or 1s ?
i plan to use on 2s "normal" battery......
Old 02-16-2012, 07:37 AM   #99
Originally Posted by corally View Post
Thanks wingman
Wingman is running 10.5 1S battery , i am running 17.5 2S layout . you can use the original position for the battery , or like i have posted above with the battery accross the rear of the car .
Old 02-16-2012, 01:38 PM   #100
wingman2's Avatar
I am indeed running a single cell LiPo. You can run the car with the battery in various locations on the chassis depending on what you require handling wise. And as Phil mentions, with the 4-pivot system, you can run a 2c LiPo across the chassis also. Got a couple of things I am going to try out and will let you know the results! Cheers!
Old 02-17-2012, 08:09 AM   #101
corally's Avatar
Thanks..
have some suggestion about roll out ? i think to use 2s with 13.5 or 10.5....
Old 02-17-2012, 11:17 AM   #102
Trader Rating: 27 (100%+)
Will the new motor mounts fit the older t-bar world gt/235 car?
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 02-17-2012, 02:07 PM   #103
wingman2's Avatar
Not absolutely sure, but I don't think so. The spacing for the bottom 4 screws are in a differant place (I think, anyway!).
Old 02-18-2012, 02:23 AM   #104
Moderator
Pro ten Holland's Avatar
It doesn't fit. The dimensions and screw patterns are different.
http://www.rc-lemans.de/
Pro ten Holland is offline   Reply With Quote
Old 02-19-2012, 06:20 AM   #105
2wdrive's Avatar
An offtopic question but the 1/12 12x has a lower axle placement in the pod when comparing it with a 10x NG, Just wondering if anyone know if the very old 1/12 corally pod (with the small fricition disc damper) come with a lower axle when comparing them to c10/c10x/f1 pod?
www.rc-lemans.de
2wdrive is offline   Reply With Quote
