Old 02-01-2012, 03:03 PM   #76
Originally Posted by wingman2 View Post
I have also been running my new 10SL (1c/10.5 boosted) recently and am really happy with it! It seems to have a ton of steering, but not at the expense of loosing rear end traction towards the end of a run. Can easily run fast, consistant laps! What are 'all the options' you mentioned? I have the new rear end parts heading my way but what other parts do you have?
How's about a couple of pics to show us all?
Cheers mate, Chris.
(Oh, and my friend said I can borrow his 2c LiPo's and 17.5 motor to try out if I wish.)
I ordered all the height adjuster holders , sidesprings , front springs , alloy standoffs , a set of titanium screws , all tyre options
I didnt know about the new rear end , but will order it over the summer ready for next year , I am using the new Thunderpower 17.5 Orion 90c 2S lipos and a Speed Passion Speedo
What colour tyres are you running ???
sidecarphil1 is offline   Reply With Quote
Old 02-02-2012, 10:59 AM   #77
It is here
Old 02-02-2012, 11:04 AM   #78
Infinite 12th's Avatar
Originally Posted by sidecarphil1 View Post
It is here
Those wheels look wicked
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 02-02-2012, 01:53 PM   #79
wingman2's Avatar
It is here
Nice one mate. I have been using all sorts of compounds to get a feel for them on the car, however, I will be concentrating on the 'spec' compounds we have to use for the BRCA national that should be coming up soon.
My wife said that a package has arrived fom Holland at our house (I am working away during the week at the moment) so will check that out tomorrow once home.
Cheers!
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 02-03-2012, 07:50 AM   #80
wingman2's Avatar
Will be fitting the new parts to the car later tonight, will post a pic once done!
Cheers, Chris.
Old 02-03-2012, 12:59 PM   #81
what is going on with the steering rods ???
they are at some wierd angle , is this normal ??? in 1:12th we usually ran them as flat as possable :-S
Old 02-04-2012, 04:17 AM   #82
wingman2's Avatar
Test fitted the new rear end parts to the car last night, here are some pics:
The new 4-pivot rear end uses a pod plate that provides the forward to back movement, whilst another plate takes care of the left to right movement. Everything is nice and free with no binding!
Will now take the parts off the car and give them to my mate to do the supergluing and sealing (which he does the best I have ever seen!). Will test in a week or two and let you know what happens!
As for the servo, I played around with the placement and found that bolting it to the back of the mounts gives the best ackerman angle plus the best bump steer angle for the turnbuckles.
Feel free to ask any questions or if you need a specific pic of something on the car.
Cheers, Chris.
Old 02-04-2012, 09:12 AM   #83
Love how after all this time they have gone back to the Corally SP10V rear suspension from 1992, the only difference is how it is sprung. It also worked well in the F1 and CCT. Should give smoother side to side movement as the pod rocks than a link setup, side links are always a compromise as the links pivot while the pod tries to move vertically.
terry.sc is offline   Reply With Quote
Old 02-04-2012, 09:17 AM   #84
Talking
So far so good
moved he battery to the left now and this balances the car perfectly
Have asked Corally for the new rear end , hope it will be sent on monday then i can fit it and test it out too
Old 02-04-2012, 10:33 AM   #85
wingman2's Avatar
Yep, I have a 10V here and it is pretty much the same except that the new parts rely on the centre shock for the springing whilst the 10V used the side 'links', which acted link a t-bar really but with adjustable positions to change the tension (if that makes sense!). I can put a pic on here if needed. Cheers!
Old 02-04-2012, 11:56 PM   #86
This will be my fairwell to this thread. Switching to a different brand after tommorow.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-05-2012, 03:27 AM   #87
wingman2's Avatar
I think I have met you in Florida a couple of times actually and I think you have always been a Corally guy, what are you going to be using now?
Old 02-05-2012, 10:47 PM   #88
You probably have since I've been racing in the series since it began in 1980.I was first a Leisure driver- Team Delta-Team Bolink and when Superior got the Corally line- Team Corally. Looking at going American- Team CRC.
Old 02-06-2012, 05:37 AM   #89
wingman2's Avatar
Yep, I went to Florida in 2005 on holiday and raced my 12th car at TQ. After that, I went down to Florida from Virginia Beach and met up with the Munno's at Adrenalin the year before last. Pretty sure you were sat next to them (did n't you have a load of stuff you were selling for someone?).
Anyway, good luck with your new ride mate.
Old 02-06-2012, 02:27 PM   #90
Ordered my new rear end today , it should arrive tomorrow then cut some tyres down and off racing sunday i hope ;-)
The Thunderpower motor has some power
looking forward to learning to drive a WGT car
