Old 05-27-2004, 08:50 PM   #46
chappi's Avatar
Trader Rating: 17 (95%+)
what about a 17T 2wind motor?
what gear ratio I should run?
chappi is offline   Reply With Quote
Old 05-27-2004, 08:51 PM   #47
EddieO's Avatar
R/C Tech Charter Subscriber
Well, I think you would need to provide some more info, like car, batteries, track, etc you are using before someone can help you with gearing.....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 05-27-2004, 09:36 PM   #48
Thanks Sushi....
BTW: How do you guys shave your brushes? Brush factory? or is there another method?
The Black Kat is offline   Reply With Quote
Old 05-27-2004, 09:42 PM   #49
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Got it, thank you Eddie.
YGM
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-27-2004, 10:09 PM   #50
Korey Harbke's Avatar
Originally posted by The Black Kat
Thanks Sushi....
Brush factory or some other sort of brush cutter woul dbe best. Because you need to have everythign centered and even on both sides. A brush cutter just works alot faster and easier. If your really super careful with a file I bet you could do it though.
-Sushi Boy
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-27-2004, 10:13 PM   #51
fatdoggy's Avatar
Do you guys know a a good setup(brush/spring/timing) for the reedy pt. A friend is running a 10x1 in mod 1/12th scale.
fatdoggy is offline   Reply With Quote
Old 05-27-2004, 11:18 PM   #52
EddieO's Avatar
Try the Reedy 729 with Green/Green Springs and about 8-10 degrees of timing. Its a good starting point.....
Later EddieO
www.teambrood.com
Old 05-27-2004, 11:22 PM   #53
fatdoggy's Avatar
Later EddieO
Thanks.
Old 05-28-2004, 04:29 AM   #54
Send a message via ICQ to Cobra81li200
You can just put a V2 endbell on the KR
Anyone hear when the V2 endbell kit is gonna come out
Don't do that, the KR uses a bigger comm it won't work.
Cobra81li200 is offline   Reply With Quote
Old 05-28-2004, 04:34 AM   #55
Try: http://www.rcshoproal.nl/easyshopmak...otororion.html
For all your team Orion stuff
840918001 is offline   Reply With Quote
Old 05-28-2004, 08:39 AM   #56
Thanks BTW: How did you come up with that s/n?
If I can get a Element/Dynasty V2 for .95 more than a endbell kit I'd take it....Wouldn't mind having a 19t arm/can around....I need some motor cans
Old 05-28-2004, 09:31 AM   #57
See als rcauto.pagina.nl
it is a site with a lot of links.
That is how I found that site.
What do you think of the new team orion 19T V2 engine?
It looks killer to me, specially because we may only run fixed timing engines in the Netherlands during the Nationals.
Old 05-28-2004, 09:44 AM   #58
Default Re: Modified motor forum.
Originally posted by speedxl
Guys there are spec and stock motors
I am going to start running mod again and was hoping everyone here would use this thread to help one another to get some growth in modified racing across the country.
This weekend i ran mod for the first time in 5 years with a d-5 i have been looking into gettin a v2 orion does anyone have expieriance with motor and the ready krypto line of motors!
Check out Banzai modified motors, they are absolutely insane!! Hand wound to any turn you want, for the price you simply can't get better motor!!
RB
RecordBreaker is offline   Reply With Quote
Old 05-28-2004, 10:49 AM   #59
serpentracer1's Avatar
Send a message via AIM to serpentracer1
Fatdoggy I run the PT 9dbl in my 12th scale.use reedy 728 brushes set timing about 12degrees use the springs that come with the motor but bend them 180 to be stiffer hope it helps
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Associated B6D
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 05-28-2004, 11:48 AM   #60
fatdoggy's Avatar
Thanks mate, you run at mimi's on wed? If so am talking about To's motor.
Want to trade Modified Motor for Stock Motor nexxus Australia For Sale/Trade 3 03-30-2007 10:05 PM
TS Modified Top .21 motor. Used.under 10 tanks of fuel through this motor like new vintagetamiya R/C Items: For Sale/Trade 7 01-02-2007 08:15 PM
Modified Motor Forum _+_+_+_+ Nexus Electric On-Road 15 05-05-2004 04:47 PM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
MODIFIED motor forum Alvin Electric On-Road 104 12-06-2002 12:32 PM
