-   -   Removing shaft from 4WD chassis (https://www.rctech.net/forum/electric-road/412574-removing-shaft-4wd-chassis.html)
jiewei1987 06-29-2010 11:43 PM
Hi knowledgeable guys!
Anyone tried removing the shaft from a 4WD chassis like TT01 or TB03 or E10 and make it into a 2WD? I thought it will become something like overdrive since only the rear wheels are spinning, but the car is very hard to control... going around in circles... any advices?
Metla 06-30-2010 01:47 AM
Originally Posted by jiewei1987 (Post 7608747)
.. any advices?
Put the centre shaft back in.
Foxxrocket 06-30-2010 07:49 AM
+1:nod:
jiewei1987 07-01-2010 05:25 AM
haha.. any advice other than putting the shaft back in? haha
Timbulb 07-01-2010 05:32 AM
Get a Tamiya M04, it's designed to be RWD.
AmmoJammo 07-01-2010 05:33 AM
take the rear dogbones out too, so its 0wd.
will handle perfectly!
Foxxrocket 07-01-2010 07:31 AM
HA... perfectly still.:lol:
MatsNorway 07-01-2010 10:24 AM
the roll resistance in the cvds are making the car less manageable. take them out too.
Make it more rear heavy-
If that does not help, abort attempt and buy a M04.
gtfour93 07-01-2010 04:03 PM
1/10 RWD
Look for a used TA03R or TA04. That might work better for you. Check the thread as well, if others have done a RWD conversion. Good luck!
jiewei1987 07-02-2010 12:49 AM
CVDs? Stands for? If I take out the front gear differential, front gearbox, front propeller joint and the dogbones, the front will be very light. But will not be able to use drift tires if not the rear wheels will just roll on the spot.
Metla 07-02-2010 01:31 AM
No matter what you do it will still suck, in a major way.
MatsNorway 07-02-2010 04:57 AM
that you should do yes. :D
did not understand that about the tires tho.
CVD stands for constant velocity driveshafts. also called universal driveshafts i believe or just unis.
