How Do You Store Rubber Tires?
#31
I wash them in hot soapy water and scrub the rims clean, then pop them into a pringles can...just gotta get rid of the contents!
#32
Evaa.
I think you meant that if your using traction compound on a hot weather, will it overheat the tires?
Okie. I am from Malaysia and the track temp is about 60 deg C (same as Philippines)on a normal hot day. I use Sorex 40R tires and Trinity Death Grip and LRP Traction Compound.
The idea of using traction compound is to soften the tires and increase grip. It has nothing to do with the temp of the tires.
If you are worried about overheating your precious rubber, i would recommend inserts that can have more air gap. That way your tires can breath when your racing on a hot day.
hope it helps
hope it helps
#33
Re: How Do You Store Rubber Tires?
Originally posted by evaa
a simple question, how do you guys store your rubber tires? ...
seriously, i just clean them with a rag and store them in a sealed bag. im not really sure if you need to put on traction compound before you store the tires. as stated earlier, some traction compounds soften the tire and it may cause them to wear quickly, especially if you keep them on for a week. ive had some old but unused kyosho slicks from several years ago and i opened them up recently, still good and sticky as new. they were packaged in a sealed transparent bag.
#34
hey evaa use my idea: i leave the tyres on the car so the next time i race i don't forget to put them on!!! hahahahaha
i have a question about my new pulsar charger. i don't know if i should start a thread or something: if i hold the positive output alligator clip on my right and the negative on my left and press the start charge button, will i feel a jolt and get fired up? i'm afraid to try
see you on the race this wed and thu?
#36
Evaa
In my tires I usually clean them with rugs then soak it to a detergent to wash away the dirt then after drying I apply WD40 wipe off the excess then I place it in a zip lock plastic. I like the idea of domoiscool and Chris08527.. What AdR|aN stated is also one best thing to do.....
#37
I use Integy tire bags or out-eatened Pringles cans. They're perfect and holds around 6 sedan wheels, and the most important: They're very tasty
#38
No wonder i can't find baggies for my pringles & sanwich to take to lunch! (I use baggies to, just clean the tires and toss them in) store them laying down so you dont get flat spots.
#39
sedan rubber - clean them with simple green, put them in a ziploc, then in a rubbermaid sandwhich holder (hold 4 nicely).
sedan foam - trinity/trc tire holders. very nice accessory to store/sort your tires.
offroad buggy - clean with simple green, ziploc, then losi carrier box
offroad truck - losi carrier box (looking to maybe start using the larger freezer bags on these.
#40
Originally posted by AdR|aN
Evaa.
hope it helps
Evaa.
hope it helps
chambs: i beleive you really have to start a new thread (in nutzracing.com)
seriously though, i beleive when u set the delta peak to match the frequency of your watch, then u might get electocuted
no really, really serious now, if your pulsar is the 24 volt version, which i beleive you have, u will definitely get electrocuted
Marvi: not a chance, after what you did to us in the opening race of kapitol speedway, you deserve monster truck tires on your ep car to slow you down, boy, you were realllllly quick. nice racing with you though.
#41
#43
I take them off the car and put them in a ziplock, if i will be storing more then a few weeks, then i put in a drop of paragon.
#45
evaa: nice racing with you guys, too i just got lucky because it rained re. simple green, do you dilute it first or spray directly to the tires? i saw some smaller containers of simple green in true value and id like to try these first
