Old 05-25-2004, 02:47 AM   #16
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
The Orion MPM is made by Much More racing or CTX
only difference is the software
i use the Orion MPM never had a problem with it and it breaks in all motors regardless of amp draw(depending on your power supply)
Andrew Swanson is offline   Reply With Quote
Old 05-25-2004, 11:25 AM   #17
V12
V12's Avatar
Regarding the Team Much More and Orion units is there a linear run-in function also or the pulse run-in only?
V12 is offline   Reply With Quote
Old 05-25-2004, 12:29 PM   #18
P2
P2's Avatar
Trader Rating: 15 (100%+)
Does both, you can run it from .1 - 7.2v contstant or pulse. On the pulse mode you select the low and high voltages and the speed/time between pulses. You can also select how long you want the motor to break in/pulse. The number of cycles in minutes and delay between cycles. I mainly use mine to run my lathe and constant voltage for break ins. I do use the pulse feature at times on new brushes.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 05-25-2004, 01:47 PM   #19
V12
V12's Avatar
That sounds great. Unfortunately I just bought the old Orion unit some weeks ago. That will work fo the moment but maybe I will upgrade later.
Old 05-25-2004, 07:54 PM   #20
F1Junkie's Avatar
R/C Tech Charter Subscriber
Hi -
I have seen these at my local hobby shop.
My question is...
With a Hobbico Power Supply (11.5 amps, 13.8 volts), will this unit be of much use to me in testing motors? Or will the power supply limit the rpms and the other features for it?
Thanks in advance...
Dave
F1Junkie is offline   Reply With Quote
Old 05-26-2004, 11:33 AM   #21
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
How many amps power supply does the Motor Manager needs to run?
Whats the difference between pulse mode and constant voltage?
When do we use pulse mode and when do we use constant voltage?
Is this equipment really a necessary equipment on our table?
Any helps would be appreciated.
AdR|aN is offline   Reply With Quote
Old 05-28-2004, 02:30 PM   #22
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I just bought my MPM, and it works fine off my 12 amp 14 volt power supply (at least for all the stock motor testing I will be doing)
my question is:
What voltage are you guys testing at for stock motors? 2.0, 3.0 or 4.8?
Buddha
RCBuddha is offline   Reply With Quote
Old 05-28-2004, 02:57 PM   #23
P2
P2's Avatar
I would say at least 25-30apm power supply. My CTX M has a max of 13apm draw. Some low turn motors draw too many amps and the CTX's protection feature beeps and shuts down. I think the Surikarn version has been bumped up to 20 amps.
Pulse mode is like pulling on the throttle and releasing. This is repeated for as long you program it. I use a Kose Turbo fan on the motor to put even more load during break ins.
Constant voltage is for running lathes and/or continuous break ins.
This piece of equipment is really not necessary but it is very handy and you get some cool points for it. It also saves having to use a 4 cell. You need a big power supply so you can charge and run the CTX at the same time.
Hope this helps
Old 05-28-2004, 03:00 PM   #24
P2
P2's Avatar
my question is:
Buddha
I use 5.0V but the numbers don't match Trinity's labels. I would start your own log and go from there.
Old 05-28-2004, 03:28 PM   #25
Hebiki's Avatar
Trader Rating: 26 (100%+)
i agree.. when i use my CTX-M... my monster pro motor says 22,800 rpm.. but when i put it in the CTX..and use 5.0 volts on it.. RPM registers at around 27,500. the highest ive gotten it is 29,800 after "tweaking".
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-28-2004, 04:39 PM   #26
mike ivy's Avatar
Trader Rating: 50 (100%+)
Where in the U.S. can I get The CTX-M
mike ivy is offline   Reply With Quote
Old 05-28-2004, 06:50 PM   #27
P2
P2's Avatar
You can try here:
http://www.speedworldraceway.com/Pag...TXM&InfoID=201
I'm not sure if Billy still carries them but he can probably order one if it's not in stock.
Good luck!
Old 05-28-2004, 09:46 PM   #28
AdR|aN's Avatar
Hope this helps
Well, the main reasong i wanna get a CTX MM is i wanan try tuning my own motors.
One thing is like you have said, i don need to have 4 cells on stand by to run in my motor and my lathe. I could use the MM to do all my stuff and still get some readings on my motors i am using.
Well, thanks for the explanation man.
Appreciated it.
Old 05-30-2004, 05:59 AM   #29
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
dont the yokomo mms has more functions the the CTX V3?!?!
FUK_WRX is offline   Reply With Quote
Old 05-30-2004, 06:19 AM   #30
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Nope the CTX V3 Has the MMS beat hands down when it comes to features and options
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
RC-Manager academygaz Electric On-Road 57 10-22-2016 03:26 PM
RC Manager kschu Malaysian R/C Racers 84 01-31-2009 10:41 PM
Motors, Spintec battery manager, MM motor cooler Clippy Australia For Sale/Trade 8 05-09-2008 09:21 PM
