SXX Comp and TC Version 2 >
Old 11-07-2010, 09:28 AM
  #106
mxracer458's Avatar
Trader Rating: 47 (100%+)
i also had some cogging issues with my v2,i was told that its really sensitive to settings.works awesome now once its dialed in!anyways i run stock class so im looking for a stock spec esc,if anyone is looking for a 2 race old v2 tc spec send me a pm,its almost brand new with everthing it came with,only ran with a 17.5
mxracer458 is offline
Old 11-08-2010, 11:17 PM
  #107
Trader Rating: 21 (100%+)
Is there any difference between the SXX stock spec, SXX version 2, and the absolute zero timing spec version when the stock spec and/or version two are place in mode 1 (blinking light, zero boost)?
Specifically; We have local racers complaining that because the SXX version 2 is not on the ROAR approved list for spec, zero timing racing... yet it has a blinking light zero timing mode...
Sean your input would be great, thanks.
-Peter Robinson
peter_robinson is offline
Old 11-09-2010, 10:03 AM
  #108
corallyman's Avatar
Trader Rating: 101 (100%+)
-Peter Robinson
Sean or Reto,
I Race with Pete, I am in the same boat here. Thanks for your response.
Steve
corallyman is offline
Old 11-09-2010, 10:37 AM
  #109
skypilot's Avatar
Trader Rating: 14 (100%+)
Pete and Steve, if you take a walk around the pits at the next race, (wednesday) you will see several non roar approved esc's. Todd and company have "grandfathered" these NON ZERO TIMING ESC's in and the racer is asked, (although never checked) to run the esc in the lowest punch level possible, (as Korey is doing). I'm not sure why following 'THIER' rules has brought any complaining, I have personally been told that the SXX v2 with spec profile and blinking light would be ok to run by the powers that be. The Grandfathering is not just for 1/12 scale but all the classes.
also if i understand right, there will be a downloadable update for the Sxx comp v2 that will give it more gitty up when run in the 'timing classes' hopefully this is correct.
skypilot is offline
Old 11-09-2010, 11:06 AM
  #110
AE-Reedy
-Peter Robinson
It is being added to the list now. ROAR has the info so just waiting for them to add those on.
If you are in the blinking light mode it will be in full compliance with the rules.
Sean Cochran is offline
Old 11-09-2010, 01:10 PM
  #111
corallyman's Avatar
Thanks Sean.
Steve
Old 11-09-2010, 02:03 PM
  #112
andrew-01's Avatar
Trader Rating: 22 (100%+)
Figured this was the case, but nevertheless thanks for letting us all know.
andrew-01 is offline
Old 11-13-2010, 11:04 AM
  #113
pakk's Avatar
Trader Rating: 80 (100%+)
I really enjoy the idea of not having to use a booster or RX pack. So I want to give LRP a shot. So I have a few questions before I purchase.
As I look at Amains site, there are two version 2's listed.
LRP SXX TC-Spec "Version 2" Competition Brushless ESC
LRP SXX "Version 2" Competition Brushless ESC
Is the only difference the heat sink and the motor limit?
are both of these ESC's competitive in "spec ramping" classes? Do they both have 0 ramping profiles for sportsman?
pakk is offline
Old 11-13-2010, 01:48 PM
  #114
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No.
You want the SXXSS for "spec ramping"
The others are designed for mod racing
RedBullFiXX is offline
Old 11-28-2010, 05:49 PM
  #115
Lee_123's Avatar
Default Dead SXX Comp V2
On Saturday 11/27 I finally was able to get out and race using my new LRP SXX Comp. V2 controller. I was good for the first two runs out. About a minute into the third run heading down the long back stretch the car died. No throttle, no steering. I took the car off the track. Thinking I had forgotten to charge it between runs I charged it up. In about 30 seconds the charger said the battery was fully charged. I plugged the battery in and the blue light on the ESC did not light up and the receiver does not respond. Tonight I checked the battery voltage is 4.08, voltage on the leads from the battery is 4.08 volts and where the wires attach to the back of the ESC is 4.08 volts, so adequate voltage is getting to the ESC.
The settings on the ESC have only minor changes. I set the first parameter for a 1s battery and the fourth parameter to the lowest setting for drag brake. Feel and boost are at the factory original settings.
Motor is a Vector X12 13.5T, roll out is 52.
When the car came off the track for all the runs the motor was only slightly warm to touch.
Just venting 'cause I have to send it back.
Lee_123 is offline
Old 12-06-2010, 07:07 AM
  #116
Trader Rating: 40 (100%+)
bump
davidl is offline
Old 12-06-2010, 07:35 AM
  #117
Trader Rating: 51 (100%+)
Default Low speed cogging
Over the weekend I was able to try out the SXX TC Spec V2 and a 5.0 Octawind in Mod TC with #4 timing insert(already inserted from factory). The speedo was set to 3 for feel and boost. I noticed at low speed there was some slight cogging, but not enough to upset the car overall. I replaced the sensor wire and made sure solder joints were good, but still slightly cogging. Any ideas on how to fix this\things to try?
Apex is offline
Old 12-07-2010, 03:22 PM
  #118
Cribbin's Avatar
hey guys,
who do you contact about getting one of these replaced? ive got an sxx tc v2 that shuts down after 30 seconds of running. thought it was the lipo cut off so i tried running without it and the problem is still there.
cheers
ben
Cribbin is offline
Old 12-07-2010, 04:22 PM
  #119
Trader Rating: 118 (100%+)
just ran mine this past weekend running Mod 5.0 TC. No issues at all, everything works as expected. Ran... 0-2-4-6, 0-1-4-7, 0-1-3-8
Must have put at least 170+ laps in over the weekend with no issues.
I would check the ALL the wiring, make sure that the sensor cable is good and is fit in correctly and snug on the back of the ESC and the motor side. I would also reprogram / set the ESC to your transmitter.
After that, if something is not working, contact AE and they will help you out.
Chris Furman is offline
Old 12-07-2010, 04:30 PM
  #120
Me_MrTyson's Avatar
Originally Posted by Cribbin
hey guys,
cheers
ben
Ben,
Sent my LRP back to germany in september still waiting for it to arrive back..
Was told more than once it has been sent
Gave up purchased something else
Me_MrTyson is offline
