SXX Comp and TC Version 2 >
Old 10-18-2010, 11:44 PM
  #76
With this device I would upgrade my tc version1 to version2?
cailas is offline
Old 10-19-2010, 07:50 AM
  #77
dmatter's Avatar
When the v2 hits the lipo cut off does it disable the motor permanantly? My car has went into lipo cut off 'on the straightaway of course' a few times and it's usually very disastrous. Most esc's studder or briefly cut out then let you bring it in or get out of harms way. My v2 makes my car sit on the straightaway to get mauled.
dmatter is offline
Old 10-19-2010, 01:43 PM
  #78
AE-Reedy
No there is no way to make an older TC into a v2. Hardware and software are completely different.
The usb bridge is to allow you to perform software updates on V2s only.
Sean Cochran is offline
Old 10-20-2010, 05:21 AM
  #79
dmatter's Avatar
I guess nobody knows anything about the lipo cut off?
dmatter is offline
Old 10-20-2010, 07:29 AM
  #80
Trader Rating: 51 (100%+)
Originally Posted by Three
The new SXX TC spec version 2 did not work very well for me using a 17.5. Ran it for about 5 laps, was noticeably slower (with factory settings) than my SXX Stock spec version 1 (also with factory settings), using a X-12 17.5 with 0 timing.
Put the SXX SS back in the car, will wait for the version 2 of the SS.
LRP SXX TC spec version 2 for sale ...............$190.00 plus shipping
Just wondering, what did your motor temp out at using the new speedo? Did you try to raise the boost or play with motor timing at all. I'm thinking if you started with the stock settings (which are geared for mod) was the problem.
One thing I do like is that the boost can be turned off for SPEC racing and the blue led light will blink to let tech know it's in SPEC mode.
Apex is offline
Old 10-20-2010, 12:08 PM
  #81
Johnny Wishbone's Avatar
Johnny Wishbone is offline
Old 10-21-2010, 02:27 PM
  #82
dmatter's Avatar
Nobody else has hit the cut off?
dmatter is offline
Old 10-21-2010, 02:30 PM
  #83
KHoff7's Avatar
When I hit the cutoff it shuts off completely.
KHoff7 is offline
Old 10-21-2010, 06:21 PM
  #84
AE-Reedy
Re-post the question. Maybe I can help.
Old 10-22-2010, 12:46 PM
  #85
dmatter's Avatar
dmatter is offline
Old 10-22-2010, 01:40 PM
  #86
Me_MrTyson's Avatar
Normally the esc would work at next charged battery
Check the sesor cable ??
Make.sure on the cables have been.cut
Is.there any flashing lights when you power on ??
Me_MrTyson is offline
Old 10-22-2010, 02:43 PM
  #87
dmatter's Avatar
Talked to some guys at the track and they said it shuts down the motor completely.....Without disabling the cut off, is there anyway I can make this esc work like the old esc's where the car just briefly cuts out and you can drive it in?
dmatter is offline
Old 10-22-2010, 02:46 PM
  #88
dmatter's Avatar
Do you like when this happens?
dmatter is offline
Old 10-22-2010, 03:07 PM
  #89
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
How long are you running on a fresh charge when the cutoff happens ?
RedBullFiXX is offline
Old 10-22-2010, 03:11 PM
  #90
AE-Reedy
I can't answer that as I never run a battery all the way to cut off. Sorry. Are you sure it is battery cut-off and not motor over heat cut off? Just asking.
