SXX Comp and TC Version 2
#31
Get some guys together and start up a mod class. Since 13.5 isn't a roar class anymore it's 17.5 or mod. For all anyone cares they can run there 13.5 with timing advance while others run a 5.0, 4.5 or what ever and you have a mod class, don't need to have the latest software and push everything to it's limits to be fast like in stock. But it all depends who's willing to start the change and get people running it
#34
Two questions:
1) When will this ESC be available / who is going to stock it?
2) will it allow you to install the version used in SXX stock spec?
#36
#37
Can't agree more with Owen Racing.
Beside, the "Plug N' Play" nature of LRP speedo will be kept and that's really good.
#38
According to version 2's manual, there is only these parameters to adjust:
- Mode 1 ACS2 (cell type)
- Mode 2 Dual ADPCmod Feel (profile)
- Mode 3 Dual ADPCmod Boost
- Mode 4 Auto Brake/Drag Brake
So where is the normal brake setting? Shouldn't there be Mode 5 as well to adjust the brake?
Does anyone know?
lrp.cc/fileadmin/lrp_anleitungen/anl_28491_ra00292-sxx-serie-vers.2-e-100519fv.pdf
Alex
Does anyone know?
Alex
#39
- Mode 1 ACS2 (battery type)
Does anyone know?
Alex
Does anyone know?
Alex
#41
I have a Sphere TC for 2 years + and this "Initial brake" was always disabled.
Brake EPA is always under 100% in most situations.
#42
Initial brake is not avaliable in version 2, but the brakes work a litle best, are stronger and progressive and same time, i never use more of 70-80% EPA brake.
I use it in Euros, and now i shell my SXX TC v1, V2 is not more powerfull, is more adjustable, i donīt need more power i like this adjustability, the motor temps are low, but i need more work in track for find the 100% of this new ESC.
Greetings, Luis C.
Greetings, Luis C.
#43
I do have both Sphere TC and SXX TC and find it's easier to have it in the speedie in addition to the adjustment available in radio if that make sense.
Alex
#44
No, it's official. I just asked a LRP driver at the late EURO in France and Luic just confirmed.
The Version 2 DOESN'T HAVE the "Initial brake" setting anymore.
