Old 02-18-2012, 12:42 AM   #286
AE-Reedy
Originally Posted by 1badgoat View Post
Thanks in advance for any help. I have just installed a sxx stock spec in a Losi 22t with a 13.5 x-12. I calibrated it, broke in the diff and tried to set the slipper. When I give it full throttle it cogs severely. It operates perfectly fine if you give it throttle slowly or when the wheels are in the air. It is geared at 8.0:1 using a 3800 2s lipo. This is my third sxx ss esc and the second time this has happened. The first time was in my buggy, but it seems to work fine when I'm on the track. I've tried different sensor cables but no luck. Everything is brand new. For what they cost I can't beleave they would come bad from the factory. What am i doing wrong?
What you are getting is the current limiter kicking in, this is normal. If you want it to stop doing this select a power setting with a higher current limit. You can use a higher setting to set the slipper then change back to the profile you prefer for the track.
Sean Cochran is offline   Reply With Quote
Old 02-18-2012, 02:21 AM   #287
piper48
Guest
Posts: n/a
Originally Posted by fasteddie d View Post
I have been waiting for a speed control sxx comp v2 that I sent in for repair at the beginning of January .
Called the people that represent lpr in north america and they advised they are waiting for the order to come in . I am trying to be patient but next week it will be a month and a half .
Oh what a beautiful indoor season its been .
Pls LRP I hope you send my speed control soon .
Originally Posted by howardcano View Post
I sent a brand-new SXX comp v2 to Associated/LRP service on December 16 of last year. I'm still waiting. I purchased the LRP because they had a "service" center in the US, but they don't actually repair ESCs, they just replace them. If there's no stock, then there's no "service" available. They're made in Germany, but it might as well be China. Associated should change the name from "service" to "exchange" so they don't give the wrong impression to people.
I hope that you at least got some use out of yours before it failed. Mine was an out-of-box failure. I spent $200 on this thing, and I've never even used it.
There are other companies that actually DO service their products in a timely fashion. Next time, my money goes to them.
HA!!! Got you both beat. Sent my SXX Comp the last week of November last year and I still haven't got it back yet.
Old 02-18-2012, 06:08 AM   #288
Buckaroo's Avatar
Not only would I call that a loss, I'd change brands if that happened to me, and I LOVE my LRP speedos. Funny how there's always stock for the retailer, but never any for the service. Hope mine never go down, might just have to contribute it to the local landfill.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-18-2012, 09:43 AM   #289
piper48
Guest
Posts: n/a
Well as much as it pains me to sit here and wait, I won't call it a loss just yet. I like LRP ESC and fortunately I got a whole season out of the Comp until I got T-boned on the straight, ESC side. I've NEVER had to send in an ESC to LRP to get repaired/replaced so this was all new to me. I figured a couple of weeks turnaround time but not the case. Totally disappointed in the service but the products are great. Let me know when you guys get yours back.
Old 02-18-2012, 10:12 AM   #290
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Don't know why I hadn't thought of that
Good call Sean
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-19-2012, 02:24 AM   #291
Hi,Has anyone had this problem?...
Firstly let me say that on forums such as these you only get posts about problems which give a negative impression of the products which simply is not the case. I have used many different makes of ESC and motors and in my opinion the LRP SXX TC Spec Version 2 with the Version 3 (Off road 1/10th) firmware is Superior in performace and quality.
I ran this setup with the firmware 1.5 for almost 12months without a problem but then shortly after upgrading my firmware to version 3 the BEC in my ESC failed. The speedo would work fine with a receiver battery but no BEC operation at all.
I sent the unit to my National distributor (SMD) and they replaced the unit FOC. I removed my old SXX TC Spec Version 1 Esc which works fine and replaced with the brand new unit just received form SMD. This unit worked fine for 2 meeting and then died in the A Final! This unit was completely dead and again I had upgraded it to Firmware 3.
I again sent this unit off to SMD and they replaced again with no problem. I received the new unit yesterday and replaced it into my car. It lasted 2 Heats and again died with BEC failure.
The ESC was run in Default mode with the flashing blue LED in neutral positions as on our tight track the extra timing and speed is not required and just makes thing run hotter.
sunktothenutz is offline   Reply With Quote
Old 02-19-2012, 04:21 AM   #292
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
yes ive had this problem a couple of times. one lasted 4 min's and the other lasted for about 4 race meetings. I've just gone back to the trusty old version 1 sxx tc spec.
mild seven is offline   Reply With Quote
Old 02-19-2012, 06:18 AM   #293
Hi,
Was this using the version 3 firmware?
Old 02-19-2012, 10:00 AM   #294
I have a brand new Sxx ver 2 TC spec.
I have loaded the version 4.0 and actually running 1-3-0-1 (the motor is an X12 5T with 13mm sintered rotor).
I have noticed at the first run (same gearing) that the top speed lowered down tremendously. I had to gear down and still need to find a good gearing to see back the original speed i Had with ver 1.5.
Has anybody had this "effect"? is it normal?
Plus: reading the instruction, the "Feel / Active Control" says "current limiter: High". Does it mean the current is limited to a higher value? or the high limiter means it is lowering down the current passing to the motor?
chobin is offline   Reply With Quote
Old 02-19-2012, 10:01 AM   #295
in addition: I have another speedo (same) installed on a Bmax with an X12 6.5T and ver 3.0 (off road spec).
I still didn't run it, but reading your previous posts I guess this software has some problems??!?
Old 02-19-2012, 10:26 AM   #296
I have loaded the version 4.0 and actually running 1-3-0-1 (the motor is an X12 5T).
The following quote is also from the manual....
"Group B (4 - 6) for use with all other motors (such as LRP X11, Novak, Tekin, SP, Orion, Epic, GM, Corally, etc)
higher value means faster power-delivery (e.g. 6 will have more torque then 4)"
I'm using V3.0 software in a SXX Comp and V2....one is in a B4.1, the other in a B44.1. This software has performed as expected for me. I've noticed no problems or issues.
sps3172 is offline   Reply With Quote
Old 02-19-2012, 11:23 AM   #297
Hi,
have you noticed the V3 firmware to be much smoother than the V1.5?..as its meant for 2wd off road...and has less adjustments than v1.5.
Old 02-20-2012, 01:22 AM   #298
From the answer on the LRP forum,it looks like its the savox servos that cause the problem!
Old 02-20-2012, 07:45 AM   #299
Buckaroo's Avatar
It's pretty well accepted that the BEC is the weak link in all of the current LRP ESCs (and perhaps the most sensitive of any out right now), regardless of servo choice. Seems silly to me to blame one particular servo brand since no other manufacturer seems to be having the same issue. If the BEC can't handle the amp draw of a stalled state commonly accepted servo, then the BEC is to blame.
Savox servos are known to be generallly higher amp draw than many others. Most only experience RX brown out when using Spektrum radios (which a 'glitch buster' usually fixes), but I suppose that enough of a load on the BEC might cause issues, eventually.
If that's the case for these, then I'll wait until the V3 BEC fix before buying another (as long as the BEC fix makes for a more robust item).
Tom Keith
Old 02-20-2012, 09:13 AM   #300
AE-Reedy
You are most likely lacking top speed because you selected 0 for the timing profile. Turn that up and you will see a big change in top speed.
Current limt high means it has a higher, more amps, current limit setting.
RC10B4/T4 Forum DerekL Electric Off-Road 14338 11-18-2017 04:19 PM
SmacTrac...St.Louis Indoor Off Road smac Kansas/Missouri Racing 24520 04-01-2015 04:02 PM
Speed Passion GT 2.0 Pro or LRP SXX TC F-1 Electric On-Road 20 07-10-2009 05:08 PM
LRP Sphere TC, SPX, or 07 Comp for 2wd off road? CaptainHowdyt13 Electric Off-Road 13 04-05-2009 02:25 PM
