Old 01-30-2012, 11:17 AM   #256
mikeygar's Avatar
Trader Rating: 14 (100%+)
PLanning to update my TC Spec V2 to the 4.0 software. Do the settings in the manual re: boost/feel/etc still apply or are there new settings in the ranges per category? PDF revision does not discuss it, only says what's new...
TIA!
mikeygar is offline   Reply With Quote
Old 01-30-2012, 02:01 PM   #257
Losiho's Avatar
TIA!
There are new settings once you update to V4. Off the top of my head, I think the boost settings max out at 6, not 10. Lipo cutoff is now just "off" or "2S". There is a new PDF manual for the V 4.0 update on the LRP website. Unlike the original manual, the new PDF revision lists the percentage of boost applied to the motor for each setting.
Losiho is offline   Reply With Quote
Old 01-30-2012, 03:17 PM   #258
Robudda723's Avatar
Trader Rating: 24 (100%+)
If I use V4 firmware can you still place in blinky mode and the other features will still works for TC? or is it all or nothing.
Running 17.5 with Novak Ballistic, can I get some recommended setting for non v4 firmware and with v4 firmware?
Thanks,
Rob
Robudda723 is offline   Reply With Quote
Old 01-30-2012, 08:56 PM   #259
Losiho's Avatar
Here's an interesting question for the LRP techs.
I have several SXX Stock Spec V2s, a Comp Spec V2, and 3 TC Spec V2s.
I recently connected a brand new TC Spec to a TC5. Worked perfectly. I also downloaded the new V4 update for it - also worked perfectly.
I just finished asembling a brand new Yokomo BD, and installed another brand new TC Spec V2 into it. It was clearly labelled "TC Spec" on the box, instruction manual, and the ESC casing. It also came with the LRP fan, as the TC Spec should.
However, when I plugged it into the LRP Bridge device, and ran the software updater to update to V4, the firmware update software told me the ESC connected to it is a Stock Spec V2, V4.4 ??
What the ??
Old 01-30-2012, 09:06 PM   #260
nerdling's Avatar
Originally Posted by Yokomo_Ant3 View Post
Id say those reading are false and the speedy isnt actually reading anything (maybe due to not using a LRP motor or LRP sensor Cable). My friend who uses a TP motor dosent get a reading also, where as my car i get a reading every time (usally flashes 4-8)
Hi Antoni,
The motor, ESC and sensor cable are all.... the same make
Its still very possible that there is a fault with the Sensor (this could result in faulty temperature readings), be it the motor or the cable. I have a different v2 that I will be running with this weekend so we'll see what's what and I'll report back my findings.
MarkW
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 01-30-2012, 09:10 PM   #261
nerdling's Avatar
I had the same thing. Ended up sending it back to the supplier and having it replaced.
What the ??
Had the same problem. Sent it back to the supplier and had it replaced.
Old 01-31-2012, 02:32 AM   #262
Hi,
do the latest sxx comp version 2 esc's come with the v3 offroad firmware allready installed?
thanks simon
sunktothenutz is offline   Reply With Quote
Old 01-31-2012, 02:46 AM   #263
Losiho's Avatar
It doesn't bother me if it is actually a stock spec, as I race in 21.5 boosted class.
Still, it's very strange.....
Old 01-31-2012, 03:40 AM   #264
Very strange.
Especially since LRP has stated that the TC and the stock spec have different hardware and their firmware is not interchangeable.
taz00 is offline   Reply With Quote
Old 02-01-2012, 01:59 PM   #265
Hi,
Can you load the LRP V3 sxx firmware on to the nosram pearl esc?
simon
Old 02-01-2012, 08:43 PM   #266
mikeygar's Avatar
thanks man,
saw the info you posted on the PDF in the zip file of the firmware. One more question - since I use this for 1s also, obviously, i should run the cutoff in "off" mode, and after upgrading it still should work for 1s right?
appreciate the response!
Old 02-01-2012, 08:49 PM   #267
nerdling's Avatar
thanks man,
I would stick with the older version of the firm ware for 1S. I've not tested the v4 firmware with 1S but prefer to have the safty net.
Old 02-01-2012, 10:24 PM   #268
AE-Reedy
Originally Posted by sunktothenutz View Post
Hi,
thanks simon
No the SCs still come v1.5 from the factory.
Sean Cochran is offline   Reply With Quote
Old 02-02-2012, 03:49 AM   #269
banquer's Avatar
Hi,
simon
I run LRP firmaware for 80955 SXX TC Spec Version 2 on my Pearl ISTC Version 2. I try all of them without issues. Remember to ugrade using LRP software and firmware. Nosram software don't reconize LRP firmware.
Cheers.
Tamiya 419
Tamiya TRF 101
MuchMore Fleta Pro - Euro - Fleta 10.5-21.5
Sanwa M12 - RX-471
http://www.agaerc.com/
banquer is offline   Reply With Quote
Old 02-02-2012, 04:22 AM   #270
H I
H I's Avatar
Trader Rating: 18 (100%+)
thanks man,
I run SXX comp with v3.0 in 1s 12th scale mod. No problem at all. I think motor and ESC runs much cooler than v1.5
When you update, donít forget to do factory reset then do mode programming (set lipo cut off to 0)
v3.0 initially set to 6.4v cut off so when you plug your 1s battery in for the first time after update, ESC go crazy as cut off kicks in (yellow/red & blue flashing fast) till you change lipo cut off.
H I is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
SmacTrac...St.Louis Indoor Off Road smac Kansas/Missouri Racing 24520 04-01-2015 04:02 PM
Speed Passion GT 2.0 Pro or LRP SXX TC F-1 Electric On-Road 20 07-10-2009 05:08 PM
LRP Sphere TC, SPX, or 07 Comp for 2wd off road? CaptainHowdyt13 Electric Off-Road 13 04-05-2009 02:25 PM
