SXX Comp and TC Version 2 >
Old 05-22-2011, 03:31 PM
  #226
Trader Rating: 39 (100%+)
I installed a sxx tc v2 into my short course for the weekend. Its probably 3 months old at this point with no more than 3-4 hours of total run time. I was 2 MIN into a qualifier and after I landed a jump(downside style jump so no hard or unusual impact) the car just shut off. The spedo had no lights on, there was no steering and the green light on my rexiever was lighlty flickering on and off. Tried another reciever and same issues. The spedo will not light up at all. I unplugged it from the reciever and the lights on the speedo flickered on and off but never stayed on or flashed. They were flickers no flashing at all. Any suggestions or anyone else have similar issues? The spedo was maybe 85 degrees when this happened and the motor was at 110. No burnt smell or anything just no power or steering. Another guy at the track had the same thing happen to his sxx comp a month ago. Same exact thing. I have read of similar stories on this forum also any answers or fix's?
Thanks in advance.
slowguy4 is offline
Old 06-24-2011, 06:21 PM
  #227
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I am having trouble. I just purchased the updating device to update my speedo. I went onto LRP's website and downloaded the software. I plugged in the updating device and connected it to the speedo and nothing is lighting up and the software says it is not connected. Is anyone else having this problem too? The speedo is SXX V2, it is brand new and I haven't even ran it yet. I wanted to make sure it had all the right firmware on it. Any help would be great.
ChadB. is offline
Old 09-27-2011, 09:58 AM
  #228
skrichter's Avatar
Default v3.0 firmware
Hoping someone can confirm the release date of the v3.0 firmware and accompanying software for the V2 series of speedos. The AE guys have been running it since Worlds.
Thx!
skrichter is offline
Old 10-18-2011, 01:11 PM
  #229
skrichter's Avatar
Thx!
http://www.teamassociated.com/news/a..._ONLINE_NOW%21
Old 11-15-2011, 03:28 AM
  #230
Hi, I have a Nosram Pearl ISTC Version 2 Brushless ESC which is essentially the same as the LRP SXX TC spec V2.
I see that a firmware update has been made available for the LRP but not for the Nosram.
Does any of you know if I can use the LRP firmware on the Nosram?
I would hate to brick my esc trying.
Thanks.
taz00 is offline
Old 11-15-2011, 04:10 AM
  #231
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Thanks.
You can use the same software on a Nosram esc
Yokomo_Ant3 is offline
Old 11-22-2011, 01:03 PM
  #232
Thank you. I tried it today and uploaded v4 of the firmware.
I will see if it makes any difference on the track this weekend.
taz00 is offline
Old 12-05-2011, 04:30 AM
  #233
H I
H I's Avatar
Trader Rating: 18 (100%+)
I just update my SXX comp to v3.0 and read instructions and seem to be v3.0 only go up to 37% boost. Iím using it for 12th scale mod races mainly on large outdoor track.
With v1.5, it was on profile 10.(0,3,10,0) Not sure what is % boost for profile 10 but would v4.0 with up to 45% boost suits me better? I use SP 5.5 1cell motor.
H I is offline
Old 12-05-2011, 04:32 AM
  #234
stiltskin's Avatar
Trader Rating: 103 (100%+)
Is it possible to run the SXX Comp V2 in stock touring (non-boost)
stiltskin is offline
Old 12-05-2011, 10:36 AM
  #235
If you set boost (timing) as 0, you get the blinking blue light signifying no boost.
So I believe yes.
taz00 is offline
Old 12-05-2011, 11:20 AM
  #236
Infinite 12th's Avatar
So I believe yes.
I thought you have to set both feel and boost to 0 to get blinky?
Infinite 12th is offline
Old 12-05-2011, 11:51 AM
  #237
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
You do with the Stock Spec, but not with the Comp.
That's why I feel the Compv2 & TC Specv2 are better for Blinky, as you can turn up the feel for more punch.
But that's just my opinion.
RedBullFiXX is offline
Old 12-07-2011, 03:12 PM
  #238
yumlailai's Avatar
Is it possible to load the Stock Spec V2 software in the Comp V2?
Anybody tried it? We are running 17.5 boost 1/12 here and want to find out if the Comp V2 will be competitive with the Stock spec with the same software
If not, will the boost and feel setting in the Comp V2 competitive with the Stock Spec V2 running on 17.5 motors?
I have a Comp already, just wondering if I can get away with a Comp 2 without buying a Stock Spec
Thank you
yumlailai is offline
Old 12-07-2011, 04:32 PM
  #239
Thank you
There is no software available for customer use that will allow you to do this.
No, the Compv2 boost will not be competitive with a stock spec for 17.5, unless you are running in blinky mode.
Old 12-07-2011, 05:13 PM
  #240
yumlailai's Avatar
How about if I use the Comp 2 in blinky touring 17.5?
and use the Stock Spec V2 for 1/12 17.5 boost, will this be better?
How about Comp 2 with a 10.5 boost 1/12 class?
thank you
