SXX Comp and TC Version 2 >
Old 03-22-2011, 10:20 AM
  #196
chicky03's Avatar
Originally Posted by Kody
Tire size is always around a 42.5 starting off. 96 spur and have been from a 23 to 27t pinion with diff speedo settings. I think when running a 26 pinion I started with 0-5-4-4. Also geared down per Kev's recommendations and ran 0-7-4-3. Went all over with boost setting trying to get power.
Any ideas will be much appreciated Paul!
Thanks,
Kody
I usually run 0,3,6,0 sometimes some drag brake, depends on the track. Have you tried the 12.5 rotor. It has more punch and you can gear it up a little. I'd use between a 24 and 26t pinion with the 12.5 rotor.
chicky03 is offline
Old 03-22-2011, 12:22 PM
  #197
No I tossed the 12.0 works rotor in it out of the box. Ill try the 12.5 tomorrow and your settings. Thanks!
K
Kody is offline
Old 03-29-2011, 09:58 AM
  #198
Xpress's Avatar
What is the supply issue in the US? Very hard to locate TC spec V2 and computer interface cord?
Xpress is offline
Old 03-29-2011, 05:15 PM
  #199
R/C Tech Elite Member
JayL's Avatar
maybe that should tell you that you don't want a v2, they don't ummm perform as we are used to from lrp......
and yes I do own one
JayL is offline
Old 03-31-2011, 08:56 AM
  #200
Xpress's Avatar
Interesting as I've had nothing but good luck with every LRP product I've ever purchased.
Xpress is offline
Old 03-31-2011, 09:49 AM
  #201
JayL's Avatar
Me too. thats why I bought it and why I run lrp octa winds in mod
JayL is offline
Old 04-02-2011, 06:03 PM
  #202
Trader Rating: 165 (100%+)
I have a LRP SXX V2 Comp paired with a Novak 10.5t SS motor. Occasionally my speedo will stop and turn mode LED to red and flash the blue set LED. I know this means there is a motor thermal shutdown but the thing is my motor is only around 125-130 degrees. Its not overgeared, if anything its slightly undergeared. Any ideas? This only happens with a long practice session.
Chris Gierse is offline
Old 04-09-2011, 06:12 PM
  #203
Me_MrTyson's Avatar
does anyone know when firmware 1.6 will be available to public?
Me_MrTyson is offline
Old 04-09-2011, 06:24 PM
  #204
I had to send mine back. It did the same thing after about 2 minutes.
M3dreamin2008 is offline
Old 04-09-2011, 09:24 PM
  #205
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
+1 V1.5 still coggs very badly.
Yokomo_Ant3 is offline
Old 04-20-2011, 05:57 PM
  #206
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
What about going to a different motor? Could this aliviate the problem?
Im going to try a Team Orion 4.5t.....
VintageFrog1 is offline
Old 04-21-2011, 10:36 AM
  #207
JayL's Avatar
I have tried:
seven sensor wires
duo2 motor
duo3 motor
novak ballistic motor
lrp x12 motor
all cog on any settings with any gear ratio
my v1 works perfectly with all above
JayL is offline
Old 04-21-2011, 12:27 PM
  #208
piper48
Guest
Posts: n/a
I'm on the verge of sending mine back also. My SXX Comp V2 cogs past 123% throttle EPA and I've got serious glitching issues. I've swapped out different motors, receivers and servos but still having some sort of radio interference. I run 75mhz airtronics receivers, three of them, in different cars and they all work fine but for some reason the SXX V2 doesn't like being paired up with old school technology I guess. I paired it up with my daughters Spektrum radio and the thing works fine except there is a slight humming noise coming from the servo in neutral position.
Old 04-21-2011, 02:59 PM
  #209
Me_MrTyson's Avatar
that is the combo of my liking, never had any cogging problems with my sxx
Old 04-22-2011, 06:23 PM
  #210
Cristian Silva's Avatar
Ive had 2 Nosram TC V2 esc die on me recently, complete shut down after a meet or two, no power or lights...nothing
Ive been running the Nosram 4.5 Octawind on low to moderate esc settings...
Has this happened to anyone and what do you guys think could it be?
Does LRP/Nosram have anything to add or explain?
Cristian Silva is offline
