Speed Power 5000mah 55C >
Old 06-29-2010, 04:47 PM
  #16
COBRARACING's Avatar
Originally Posted by cannon View Post
Certainly disguises the original manufacturer. Remember there is no official C rating system so anything can be put on them
spot on Greg you would be suprised which batterys are a true c rating lol.
The c rating is very important when it comes to running a low turn and high current esc .Lipos puff because the esc is continuesly demanding the battery discharge at a rating above the safety net that the battery c rating can handle .So then when you charge the battery after the damage has been caused to the battery (leaking cells) the battery will overcharge when that happens the extra charge must go somewhere so it ends up on the outer layer of the cells in a gas form causing the cells to puff usually it happens to one cell only of a two cell battery and sometimes on both cells depending on the extent of the damage.
Even when a battery states that it can be charged at 3c,4c or even some specify 6c is possible i would only charge between 1c and 2c max and always balance the cells always .I have seen on many occations were a racer would fast charge a lipo without balancing the cells then they complain why the short life span of the battery .
when it comes to lipos they are dangerous when rules are no followed only .
COBRARACING is offline
Old 08-05-2010, 05:58 AM
  #17
Suspended
Trader Rating: 4 (75%+)
did anyone used speedpower 5800 55c? hows 55c compare with speedpower 40c and 45c??
amygal is offline
Old 08-05-2010, 08:12 PM
  #18
irgo's Avatar
There is 2 C rate For Lithium Batteries :
- C Charge rate
- C Discharge rate
Lipo C Charge rate is designed for 1C Charge only
Life C Charge rate is designed for Higher C Charge rate ex : 4C Charge rate.
charging high rate on Life is not abuse, since it was designed for.
that is why the voltage comes lower 3.3v per cells or 6.6v (2S).
so 55C on this battery is C Discharge rate, would always better and safer
for the lipo to run high load such Mod motor.
but for such great Discharge at same capacity, will let your Battery drain quicker than ever, as your car run faster.
but keep it charge at 1C no more than that, cause lipo is designed for.
irgo is offline
Old 08-06-2010, 01:05 PM
  #19
Born2Run's Avatar
55C? Yeah, sure.What do we have next? 60C or maybe 65C?
Born2Run is offline
Old 10-10-2010, 07:26 AM
  #20
jaggededge's Avatar
Old thread but I'm researching lipos.
This is crap and is going to continue.
We're being played and look like fools to keep buying the latest higher rated packs. 60c? BULLSHIT. For what a millisecond? Why? Oh that's right, I'm fooled into believing its better and I should buy it. Continuous should be continuous, not continuous for a millisecond.
Combined with the "ROAR approved" bs makes this hobby suck.
I'm glad to see Roar puts the packs through destructive tests. Hopefully they are actually verifying the ratings.
I seriously feel sorry for the kids who have to come up with 4 times the money for a pack because ROAR says so.
jaggededge is offline
Old 10-22-2010, 09:33 PM
  #21
JKL1031's Avatar
how are these suckers? A 5200 35c or close. on the direct site, their prices are taken down and are in the works.
JKL1031 is offline
Old 10-23-2010, 12:06 AM
  #22
I agree with you 100% but with our pro amps batterys and not because we are part owners we do have 60C rating and true 60C we also supply every battery with its own test data sheet per batch manufactured .
every battery we sell comes with its own test data sheet with it graph readings ,temp,pressurization testing ,altitude testing the lot .
Thats what you need to ask for its test data sheet as all batterys should be true and have the information available for the buyer .
Just mt two cents worth
Old 12-09-2010, 11:38 AM
  #23
Default Lipo Battery
I had a 5300mAh 40C and 5800mAh 55C, I found out my 40C is much faster than the 55C. I may try 5300mAh 45C. I hope it will give me the same speed as 40C.
carcar188 is offline
Old 12-09-2010, 11:41 AM
  #24
Default Battery
For the same setting on my car, 5300mAh 40C is faster than 5800mAh 55C. Any reason for this? Can you help me out? thanks
Originally Posted by Solara View Post
About whos OEM what, this and that...is absolutely un-necessary. You buy what you like, where you like, and how much you like....but if IP don't even have the 5000mah 55C lipo, in what way they can OEM that to Speed Power and ppl will know that it is an IP pack...? Beside....who would really want to open up a BRAND NEW in PERFECT CONDITION lipo, and find out it is OEM by someone else, and will get upset about it..? Totally not necessary..............
Not to mention...the price on these pack at Speed Power website, is amazing. (please look at the below link).
I have been running the Speed Power 5000mah 55C 7.4V Racing Lipo battery, the 5300mah 45C 7.4V Racing Lipo battery adn the 5800mAh 55C 7.4V LiPo battery for more then 2 months on my TC (all with SC, 17.5 and 13.5 and mod 4.0)...I don't "baby" my lipo at all...I raced them, then charge them without waiting and cooling (that is what I have always do to ABUSE the batteries to see any problem will happen)...so far, all 3 lipo has no puff and always @ 8.44V and above (alot of time while I was doing tech, I have to drain the lipo a little to pass the tech). So far, within these 2 months...I have not even balance these 3 packs yet. And I am sure it will take no more then a minute to balance them if I am going to balance them in purpose.
You can buy direct here....or contact your local Speed Passion, Speed Power, East Coast Bodies Tunned dealer...aka, your hobby shop.
http://www.speedpowerrc.com/en/productDetails.asp?p=46
Speed Passion USA will provide support for all Speed Power items.
Old 12-09-2010, 11:45 AM
  #25
Alberello's Avatar
Are they from different brands?
Alberello is offline
Old 12-09-2010, 12:24 PM
  #26
Default Speed Power
They are the same from Speed Power, since I brougth the 5300mAh 40C, it was awesome powerful. But when I used the 5800mAh 55C. It kind of slow pick up with the same setting on my T3.
Old 12-09-2010, 09:32 PM
  #27
bigz's Avatar
balance charge it, usually in the first charge they are noticeably slower but power comes in after three or four full charge.
bigz is offline
Old 01-11-2011, 07:19 PM
  #28
I think it's slower because the 5800mah 55c battery is heavier. Same happens to me for my Yokomo BD5. It was faster when it was strapped to the Turnigy 5000mah 20c then then 5200mah 30c.
durkheim is offline
Old 01-13-2011, 05:16 PM
  #29
SavageCanadian's Avatar
Trader Rating: 60 (100%+)
I ordered 2 of the 5000 55c on the 21st of December and still havent seen them yet. Anyone else experience the same thing? Sent them a email, no response, and there phone numbers dont work. Not really impressed with them so far.
SavageCanadian is offline
Old 01-14-2011, 08:20 AM
  #30
georgec's Avatar
Glad I ran across this thread as I was about to order two of the same! Please re post with the final out come of your order!
georgec is offline
