Like Tree5566Likes
USGT
    Hide Wikipost
Old 08-12-2017, 12:28 PM   -   Wikipost
R/C Tech ForumsThread Wiki: USGT
Last edit by: DARKSIDE
USIC USGT 2016 Motor and Chassis list in qualifing order
TQ A.F. TSR A800
2nd D.J. TeamPowers A800
3rd B.S. TSR A800
4th M.L. TSR A800
5th M.F TeamPowers A800
6th D.J TSR Destiny
7th J.W. Trinity Monster '17 Xray
8th C.V TSR Destiny
9 A.C. TSR A700
10 B.K. R1 v15 A700
11
12
13 J.L. TSR A800
14 M.L. TSR Destiny
15
16 J.M. TSR. 15 Xray
17
18 R.C. TSR T4
19 M.K. Reedy Powered M3 AE TC7
20 S.J. TSR Destiny
21
22 E.S. motiv T4
23
24
25
26 P.D. TSR Destiny
27
28
29
30 V.P. Reedy M3 serpent 3.0
31
32
33
34
35 Y.B. Fantom A800
36
37
38 R.C. TSR A800
39
40 W.S. Reedy
41
42
43 Motiv xray
44
45
46 Motiv Xray
47
48
49
50
51
52
53
54
55
Print Wikipost
Old 02-10-2022, 08:33 AM
  #11041
Originally Posted by timberline97 View Post
Just to check, are you using tire sauce?
Also, when I first started running usgt, I was told it helps to sand down the middle ridge off the tire. My routine is to clean the tires after coming off the track with break cleaner, then 5 mins before getting on the track, sauce the tires. Then when you set the car down, hold the car and hit the throttle a few times and run.
Don't know if you're running (outdoors) on asphalt, or (indoors) on carpet...but, most indoor carpet tracks don't allow sauce.
Panther6834 is offline
Old 02-10-2022, 08:34 AM
  #11042
Trader Rating: 20 (100%+)
Originally Posted by Panther6834 View Post
Don't know if you're running (outdoors) on asphalt, or (indoors) on carpet...but, most better tracks don't allow sauce.
Indoor on black carpet. Both tracks I run on allow SXT 3.0.
NutDriver likes this.
timberline97 is offline
Old 02-10-2022, 12:15 PM
  #11043
mrreet2001's Avatar
Is this some sort of West Coast thing? All of the tracks that I am aware of in the mid west allows SXT 3.0.
mrreet2001 is offline
Old 02-10-2022, 01:12 PM
  #11044
DirkW's Avatar
Over here there's no sauce (like none ever, at all) in Off-Road, but in On-Road, it's pretty much universal standard (odorless is required however, in most places. Luckily.)
DirkW is online now
Old 02-10-2022, 01:23 PM
  #11045
Trader Rating: 15 (100%+)
Definitely NOT a west coast thing. Here in SoCal, we run all sorts of tire additive. Only stipulation for indoors track which are non existent now but that required odorless. Outdoors, anything goes. Lol
trigger is offline
Old 02-10-2022, 05:16 PM
  #11046
That was a typo...sorry. It should have read "most carpet tracks...". I'll correct it now.
Old 02-10-2022, 07:10 PM
  #11047
The tire puffing is why the droop gauge number is innacurate, and we use droop over ride height in VTA and USGT. the TC tires are belted so thier size stays pretty much, but the VTAs and USGT tires are not belted currently. If i have new tires at 65mm and u have old ones at 69mm, to get the same amount of droop over ride height, we will have 2 totally different gauge numbers. my rule of thumb is if your over 68mm ur close to needing new tires.
if u ever wonder why folks can get away with no glue its from having fresher tires.
ultimately, you can fight the aged tires, and make setup changes to compensate, but at the end of the day its a bandaid for the inevitable.
thirtydaZe likes this.
drivercorycraig is offline
Old 02-10-2022, 09:09 PM
  #11048
Everyone uses SXT 3.0 at the track. I just started using brake cleaner.
Just so I understand completely.....clean the tires with brake cleaner after every run. Then sauce them 5 min before the race and do a burnout on the carpet to get the excess sauce off them.
Am I leaving anything out? I've only used sauce on VTA tires. Never used brake cleaner on them. it took a race day or two before new vta tires would wear in.
Also, when I do sauce the front tires in USGT, am I only saucing the inner half of the tread or doing the entire tread across?
Flare65 is offline
Old 02-10-2022, 09:12 PM
  #11049
no, that is exactly what I do.
on usgt, I usually do about a quarter of an inch on the inside. On vta, I do the inside first two tread.
Old 02-11-2022, 10:44 AM
  #11050
bd007's Avatar
Didn't you ask other people at the track? Then, you could have fixed it at the spot instead of wasting track time.
To break-in the tires, I would sauce the whole thing front and rear.
bd007 is offline
Old 02-12-2022, 10:10 AM
  #11051
theproffesor's Avatar
Trader Rating: 66 (100%+)
I’ve have yet to see a carpet track that didn’t allow sauce. If you know of one ( or more) that don’t, could you please let us know? And what is there reasoning?
If you are intending to say they don’t allow paragon or anything like it, or costic cleaners that will stink up and give off toxic fumes indoors then yes I agree. I do know carpet tracks that limit tire sauce to SXT 3.0 or similar.
mrreet2001 likes this.
theproffesor is offline
Old 02-13-2022, 03:32 AM
  #11052
Where I raced, sauce on the carpet was banned.
Why? The venue we hired was carpeted, so we raced on it, kept it clean, and in good order.
Bloke is offline
Old 02-13-2022, 03:52 AM
  #11053
DirkW's Avatar
So you raced in a non-permanent facility and used the normal office-type carpet that was on the floor there already? Well, in that case I can understand banning sauce, but that seems to be a rather special case, not the norm.
DirkW is online now
Old 02-13-2022, 08:11 AM
  #11054
oldfool's Avatar
Isn't that gonna mess up the carpet if everyone does it?
Originally Posted by theproffesor View Post
I’ve have yet to see a carpet track that didn’t allow sauce..
Yeah, which is it.
Rick Vessell likes this.
oldfool is offline
Old 02-13-2022, 08:13 AM
  #11055
Billy Kelly's Avatar
Yeah, which is it.
Most usually have a separate carpet square to burn off the extra tire sauce.
Billy Kelly is offline
