Help with Cyclone TC setup >
Old 06-24-2010, 04:35 PM
Default Help with Cyclone TC setup
I have a Cyclone tc and put in a Tekin RSPro with a 17.5 motor.
What should my FDR be? Rollout? Trying to figure out what Pinion and Spur I should start with.
hannigan13 is offline
Old 06-24-2010, 05:12 PM
RaceAce701's Avatar
Trader Rating: 87 (99%+)
depends on track size and ur timing and boost setings
RaceAce701 is offline
Old 06-24-2010, 05:45 PM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
It completely depends on the settings you set in your RS, what motor you are running, how you drive the car, and what kind of track you will be running on. Your best bet is to go into the Tekin RS thread and look for info there.
For example, if you ran very little or no timing on your RS pro, you could gear the car with an FDR around 4.0 or 4.5. If you ran max timing, max turbo, etc... you could be geared as short as 6.5.
I other words, it depends too much to just give you 1 answer. Go to the Tekin thread.
Cpt.America is offline
