Old 09-06-2001, 03:24 AM   #1
TRF-Powered's Avatar
Default Homemade discharger
I just wonder when you make a discharger which configuration is better for assemble the light bulbs? Series or Parellel?
TRF-Powered is offline   Reply With Quote
Old 09-06-2001, 11:58 AM   #2
Default Re: Homemade discharger
WHAT????????????
I don't think it matters on a ligt bulb
because it just takes the power and turns it into light
Wolverine is offline   Reply With Quote
Old 09-06-2001, 02:42 PM   #3
You must put the bulbs in parallel. If you don't it won't discharge at about 2 amps per 1157 bulb used. It will discharge at a MUCH lower amperage.
Dave
Dave Nichols is offline   Reply With Quote
Old 09-06-2001, 07:39 PM   #4
Trader Rating: 69 (100%+)
parallel is the only way you should solder the bulbs to make a 20 ampere (for 10 pcs 2 ampere 12 volt bulbs) discharger. if you solder it in series, the volts would add up, and i think the bulbs wouldnt light at all.
marvi is offline   Reply With Quote
Homemade Rcs? ManiTech Singapore R/C Racers 24 06-13-2008 06:44 PM
homemade bodies for the X-Ray M18 LimmetED Micro and Mini Scales 3 12-12-2007 06:36 AM
Best way 2 make a Homemade Discharger? jono mad racer Electric Off-Road 12 10-23-2007 04:01 PM
homemade discharger jono mad racer Radio and Electronics 2 10-21-2007 07:31 AM
Homemade TC3 Spool Dane Electric On-Road 6 04-09-2005 06:44 AM
