HPI RCGT
Old 07-21-2010, 12:10 PM
  #76
mlight13's Avatar
Trader Rating: 40 (100%+)
Originally Posted by speced View Post
Has anyone tried the Integy X2 tires? If so, how do they compare to HPI's. The tread pattern is the same but I'm curious about the compound.
http://www.rcplanet.com/Integy_26mm_.../intc22358.htm
Based on price alone, I would expect the Integy X2 tires to be similar to the HPI D-Compound X-Patterns. One of the main differences I can see is the inserts. If you go to the Integy web site and look at the picture of the "imposter x-patterns" the insert looks to be a thinner and harder insert like TC tires. Not the cheap puffy foam inserts that HPI uses. At my local tracks, tires may be randomly squeezed to see if the correct inserts are used.
mlight13 is offline
Old 07-21-2010, 03:06 PM
  #77
robk's Avatar
Trader Rating: 22 (100%+)
I just got some in the mail. They feel exactly like pro compound non belted tires. The insert is a cheap neoprene foam-not very good. I'm sure you could get the regular X pattern inserts and it would be fine.
robk is offline
Old 07-31-2010, 02:38 PM
  #78
i got my 17.5 in my car now. and might as well show my new homemade cooling fan for the car when its at the pit table.
Attached Thumbnails HPI RCGT-downsized_0731001627.jpg   HPI RCGT-downsized_0731001624.jpg
Austin Strykul is offline
Old 08-15-2010, 09:15 AM
  #79
oldpugva's Avatar
Arrow New RCGT Sedan
Let's see pics of yours!!
TC4, Novak Havoc Pro/Ballistic Brushless System 17.5T/2200kV, Hyperion 5000 mAh, HPI X-pattern tires, Nissan 350Z body.
Attached Thumbnails HPI RCGT-hpim0078.jpg   HPI RCGT-hpim0081.jpg   HPI RCGT-hpim0084.jpg   HPI RCGT-hpim0085.jpg   HPI RCGT-hpim0086.jpg
oldpugva is offline
Old 08-15-2010, 10:52 AM
  #80
RC-ProSpeed's Avatar
Any feed back on how they handle compare to the hpi x pattern? Same as 4490 / 4495?
RC-ProSpeed is offline
Old 08-15-2010, 03:58 PM
  #81
Sith Lord's Avatar
Trader Rating: 21 (100%+)
http://www.rctech.net/forum/electric...-them-off.html
Sith Lord is offline
Old 08-18-2010, 12:03 PM
  #82
lightfoot's Avatar
kinda of a dumb question but I would rather check before I order...
I have a 190mm body with 0 offset wheels... I'm going to a 200mm body... what offset wheels should I get ?
Thank you in advance
lightfoot is offline
Old 08-18-2010, 06:59 PM
  #83
snoopyrc's Avatar
I like 3mm in the front and 6mm in the back, but that is really just preference. Its one of those things that you will know better after trial and error.
Remember that just because it says its 190 doesnt really mean that it is. Some are 188mm and others are wider than 190.
snoopyrc is offline
