Mid-Motored TC3? >
Mid-Motored TC3?
Mid-Motored TC3?
Old 07-03-2004, 04:51 AM
  #106
Xtant3150c's Avatar
Thumbs up
Congrats on the race/test! Chassis set up looks good! I hope things keep moving forward for your chassis!
Xtant3150c is offline
Old 07-03-2004, 08:08 AM
  #107
b3buggy's Avatar
hi guys,
another sucessful outing last night, learned a lot about a few things. set FTD , but with limited drivers, seemed very quiet
nearly converted another driver to actually buy one, rather than just helping with testing.
Might have a tootle around after the Junior natinals tommorrow, depends on weather.
Ross
b3buggy is offline
Old 07-04-2004, 06:23 PM
  #108
slide the batteries more forward
R/C Anonymous is offline
Old 07-05-2004, 03:40 AM
  #109
tornado
Guest
Posts: n/a
Originally posted by b3buggy
no kidding sherlock
cannot divulge that info, need only basis.
might be ran on wednesday, if not definatly on friday, will get some ''action'' shots hopefully.
Ross
Keep to yourself mate ...........don't understand wots the BIG secret is all about. Its no secret that your motor mount is CGM's...and the spur holder too.........
Old 07-05-2004, 10:03 AM
  #110
b3buggy's Avatar
hi guys,
tornado: only winding you up! dont think you guys get british wit.
like i said, off the shelf parts, makes finding spares easier, dont want to break it and it to be the only one in the world. Also have you tried to find a machine shop close to where i live! would machine parts for it myself but dont have the facilities.
R/C ann.: why move the batteries forward? the balance seems good, and has more initial steering than a standard tc3, due to more weight being at the front than normal. also not that much space available, maybe could move it one mil .
Ross
b3buggy is offline
Old 07-05-2004, 09:04 PM
  #111
tornado
Guest
Posts: n/a
hi guys,
I'm twisted already.....
Old 07-05-2004, 09:33 PM
  #112
Wency_TA03R-PRO's Avatar
Exclamation
Hi guys,
the car ran last night at a local carpet track. ran it with a friend who is helping to develop the car. He took FTD with it. not a bad start. seems well balanced .
heres a pic with the electronics in. enjoy!
Pic1
Ross
Great!!! it seams a great project or prototype of TC3.. So did you use a 3mm thick carbon fibre chassis or same as the existing?.
Another one what body shell did you use?. stratus/mazda?.
Wency_TA03R-PRO is offline
Old 07-06-2004, 11:09 AM
  #113
b3buggy's Avatar
Hi Guys,
using 3mm chassis with 2mm top deck at the moment.
Will try a few different size top decks and designs if i have time.
Nope used a Vectra!
will be recieving some new parts tommorrow hopefully, and have started to fine tune the car to make it more to my liking in mechanical terms.
Ross
b3buggy is offline
Old 07-06-2004, 04:18 PM
  #114
Exclamation
ok.. Hope to see this prototype in action and the finish product as well... tnx...
Old 07-06-2004, 07:53 PM
  #115
protc3's Avatar
i would definately try 3mm c/f.3mm seems to have more memory and helps eliminate tweak.use the width of the upper deck to adjust how much flex you need in your chassis if any.try cutting a thin one and a wider one and see which you like better.looks very nice though.good luck with it
protc3 is offline
Old 07-06-2004, 08:01 PM
  #116
Trader Rating: 17 (100%+)
from the pics there is plenty of room to move the batts forward a fair amount, forward = better
Kave is offline
Old 07-07-2004, 10:20 AM
  #117
b3buggy's Avatar
Hi guys,
thanks for the comments.
pballkid21587: can you please elaborate?
Ross
b3buggy is offline
Old 07-07-2004, 10:24 AM
  #118
forward transfers more weight to the front giving even more stearing. Also there is not a problem with rear traction so the more stearing you can get the better. Also with more stearing it alows you to explore more on the setup side.
Kave is offline
Old 07-07-2004, 10:40 AM
  #119
b3buggy's Avatar
thank you pballkid21587.
Remember there is more weight at the front than normal anyway. and there is more than enough ballast to move around.
thanks for the comment, i will look futher into it if i start having problems.
ProTc3:
thanks for the comment, i was going to make a few top decks, i already have some in the works. I mainly run on tarmac so have gone for a 2mm for the first one.
If i run carpet then 3mm would be better- but as we dont run foams over here very often 3mm is not essential.
I have done done a flexy top deck for my warpspeed, and so will copy the main idea from that for the flexy one.
More than anything i just wantd it running
Ross
b3buggy is offline
Old 07-07-2004, 11:06 AM
  #120
glide 1's Avatar
Default b3buggy
looks very nice!!... are both the front and rear shafts the same length? and what are they made of?
glide 1 is offline
