Old 05-24-2004, 09:52 AM   #16
rayhuang's Avatar
Thanks all. I borrowed a big battery that was used on a fishing boat all summer. I forget to check its CCa and Mah ratings. He charged it at 2amps overnight and I picked it up on way to track.
I should have paid more attention, but on its 4th charge it was still at 11.6 volts.
I charged 5-3300 packs from a trayed state and peaked 6 batteries. The charges were about 32 to 38 minutes and the peaks about 3 minutes.
I am not at all sure how many more charges I could have gotten, but I did get through the night with no problems.
Thanks for all the info,
Ray
Old 05-24-2004, 01:11 PM   #17
speedxl's Avatar
R/C Tech Charter Subscriber
ray probably needed to be charges longer.
like an r/c battery they will go flat sitting on the shelf.
sometime those batteries need about 24 hours of charge time.
static voltage is useually 12. 4 to 12.6 vlts
on a good known batt. a batt is usually dead when the vlts are around 10.9 volts.
at that point a car wouldnt start and most gm cars will rum into drivabilty problems.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 05-24-2004, 01:16 PM   #18
rayhuang's Avatar
Cool!! I dont know what the voltage would have been with a voltmeter and nothing charging at the time. Might have been higher??
Old 05-25-2004, 03:32 AM   #19
Simon K's Avatar
I use a 4 amp charger overnight on a smallish Deep cycle 12v battery and thats sometimes not enough to fully recharge it if I've really flattened it the previous day.
A larger battery will take much longer, especially at 2 amps.
Simon K is offline   Reply With Quote
Old 05-25-2004, 04:06 AM   #20
I use a 110ah leasuire battery and over the weekend got 20 charges out of it. On the last 2 charges, I had to drop the charge rate from 5.5a to 4.5 (well, my charger did it) but the cells worked fine, very "power hungry" track, which needed my best 3300's!
TraceRacing is offline   Reply With Quote
Old 05-25-2004, 09:21 PM   #21
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
anyone get weird behavior when charging at lower amp rates? like 1 amp? My charger went nuts.
Old 05-25-2004, 10:00 PM   #22
Ray,the battery you used was charged at 12 amps but goes into an automatic trickle charge.Though it was the first charge in a couple of months.I usually keep them charged evey month during the winter but do to my surgery this year ,I am a little behind.
GRIZZLY-A is offline   Reply With Quote
Old 05-25-2004, 10:01 PM   #23
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
i bought the 12v 7amp battery from hobbico for starter boxes, i usually full charge my batts at home and just use the 12v to repeak a run, i only have 2 packs at the moment and havent gone more than 2 full charges on the batt, but it took it pretty well, stayed at 5 amps(charger max).
should i ditch this battery and just use a real car's batt?
R3VoLuTiOn is offline   Reply With Quote
Old 05-25-2004, 10:03 PM   #24
rayhuang's Avatar
And so may, many thanks to you for letting me borrow it. I have to load up car-then 2 minutes later swap all the stuff into another car a few miles away early tomorrow what a pain!!! but the battery will be in it. I have not charged it.
Thanks again,
Ray
Old 05-25-2004, 10:11 PM   #25
popsracer's Avatar
Default Charging on 12v car battery
rayhuang;
When I first started back up in Electric racing, I could charge about 8, 2000mah packs @ 5amps or less with a fully charged 24F Automotive Battery.
As I got more competitive my charge rates and Mah went up, the number of charges went significantly down.
I think you would be hard pressed to make a full day of practice and racing (5+ packs) on a full size Auto Battery charging 3300 packs at competitive charge rates.
Steven
popsracer is offline   Reply With Quote
Old 05-26-2004, 01:25 PM   #26
speedxl's Avatar
yes pops your right back in the day i would charge about 10 to 12 1200 or 1700 mah batteries. but take modern batts at 3300 that would be about half.
Battery Charging rf096 Racing Forum 16 06-01-2015 03:24 PM
Charging Ni-Cd battery jayliu1984 Electric Off-Road 8 02-27-2008 11:32 AM
Battery Charging t4mania Electric Off-Road 7 08-16-2006 09:41 PM
Battery charging? Maxxcrazy Electric Off-Road 1 05-11-2006 03:31 PM
Battery Charging nerdling Electric On-Road 10 06-21-2005 11:31 AM
