Old 01-24-2011, 12:14 PM   #121
Conrad's Avatar
Finally got around to buffing up my plates and fitting the ceramic balls, woooo smooth, what a difference Even my well seasoned TC4 mate was impressed. You were spot on Dave, thank you kindly
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 02-16-2011, 11:57 AM   #122
Suspended
Hi everybody, I also run tc4s and switched all my front cvds for losi jrxs typeR lcds, and never broke anymore drivetrain parts again! I did have to dremel the castor blocks a bit, but it was worth the effort: no more chatting , tighter steering radius, more traction, and I do not have to wait for the car to straighten up before accelerating etc...It seems that everybody uses lcds in the front now: tcx, losi, awesomatix etc....
bertrandsv87 is offline   Reply With Quote
Old 02-16-2011, 01:24 PM   #123
Hey guys. I'm doing a big tune up on my car at the moment. I have most the rear end taken apart to do a number of fixes. Also redoing my shocks. Just figured while I'm in doing stuff, I might as well do it all. Looking for any extra performace. Last club race, my car was rediculously loud. I got some new gears along with my parts in the mail yesterday. im hoping that will take care of it. What else can I look at? I've never touched the bearings in my hubs. Should I clean them? Just rotating my wheels feels more difficult than it should be. I'll try sanding my rear diff as described and maybe clean the diff balls. What else can I do to increase efficency? What other maintenence should I do? Thanks! Dan.
Dan Fowler
Getting out of the hobby... Check out my for sale thread.
TC4Racer123 is offline   Reply With Quote
Old 02-16-2011, 02:44 PM   #124
Foxxrocket's Avatar
I never buff, or go any higher than 600 grit when using sandpaper. You want the diff balls to get as much grip, without slipping. Sanding the D-pates will give the diff added grip.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 02-16-2011, 06:12 PM   #125
Put my car back together tonight. Its handling 300% better, and it actually sounds good! And when I let off full throttle, the wheels keep spinning 4 times as long as they were. Needless to say its doing a lot better.
Dan Fowler
Old 06-03-2011, 11:36 PM   #126
Meradin's Avatar
Trader Rating: 19 (100%+)
Anyone have a picture of the slipper spool mentioned?
Meradin is offline   Reply With Quote
Old 02-27-2012, 03:56 AM   #127
did anyone here already sucessful with yokomo cs kit FCD implementation?
or just plug and play?
need answers please
THX.........
j3fron is offline   Reply With Quote
Old 01-04-2014, 11:09 PM   #128
Schs2013's Avatar
Would the cvd's of a TC5 work in a tc4? I was going to try it out but just wonder has anyone else done this to replace the stock dogbones of a TC4 to give it all the turning ability.
VBC Lightning 10LM 21.5, WCICS spec M05v2, VBC D07 21.5 USGT
Schs2013 is offline   Reply With Quote
Old 01-05-2014, 01:26 AM   #129
Check out post #12329....Associated TC4 thread. Sounds possible but a lot of work!!
THEBIGBULL is offline   Reply With Quote
Old 01-05-2014, 09:38 AM   #130
Schs2013's Avatar
Thanks TJ i was looking for that.
I guess my question on this thread wasn't worth writing it.
Old 09-03-2014, 04:03 PM   #131
boudin4evr's Avatar
Trader Rating: 18 (100%+)
since Losi part number 3344 has been D/C'd, what cvd's are yall using in the tc4?
I ned more steering angle or throw!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 09-03-2014, 05:00 PM   #132
oreo's Avatar
.....TiR TC-3 CVD's is what i'd bought a decade ago......these are nothing too special (except for their price tag). The same angle (turning circle wise) was acheived. There has to be a set of Losi parts to build up a pair of LCD's someware . Anyways , good luck on a never ending era/journey with the
TC-4.
Rc 10L (x6)
(.......in 2010, I jus' may get to run one.)-Irrgang Racing Service;TeamCRP. R.I.P. Billy 105
oreo is offline   Reply With Quote
Old 10-19-2015, 08:10 AM   #133
Trader Rating: 17 (95%+)
I hate to bump up this old thread but I really need help here. I have a fully built and customized TC4 with a carbon chassis and a cracked aluminum motor mount. I currently have it sent off to a guy that has a 3d printer and he's going to try and create a motor mount for me and I'm also searching for a new one; obviously to no avail.
What other options do I have to install a motor mount on my chassis? Does anyone know where I can locate one? Any help is appreciated.
Pintobean11 is offline   Reply With Quote
Old 10-19-2015, 08:56 PM   #134
Suspended
You can try to weld it carefully unless it's 7075 , but another motor mount will be hard to find without buying a whole car.....
Old 10-19-2015, 09:05 PM   #135
DesertRat's Avatar
http://www.diggitydesigns.com/Diggit...otorMount.html
Perfect replacement.
Crap, out of stock as well. Oh well, maybe they'll make more.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
LOSI XXX-S, Tips and Tricks, Open Mod, etc John Stranahan Electric On-Road 1057 12-08-2017 06:19 AM
