spring charts
Old 05-19-2004, 09:16 PM
SalvadoriRacing's Avatar
Default spring charts
Hello,
i'm not sure if I saw on this forum, was a post with a link to a website containing a spring chart os many brands, like associated, xray and others.....
if anybody knows this website please post here!!!
thankz!!!!!
SalvadoriRacing is offline
Old 05-20-2004, 12:05 AM
PizzaDude's Avatar
you mean this one?
http://www.rcingreece.com/index.asp...on&super=38
PizzaDude is offline
Old 05-20-2004, 12:55 AM
tornado
Guest
Posts: n/a
Originally posted by PizzaDude
you mean this one?
The link don't work
Old 05-20-2004, 01:02 AM
Shop Owner
nnick's Avatar
The correct link is
http://www.rcingreece.com/index.asp?...rison&super=38
It looks the same but is isn't! (after the www.rcingreece.com/ comes the index.asp?prev=6&page=spring_comparison&super=38)
Nick
nnick is offline
Old 05-20-2004, 02:41 AM
evaa's Avatar
i have a chart with a list of weights and colors of the springs of xray, associated (TC3) and Losi (xxx-s). i'll post it tom when i get back to the office.
evaa is offline
Old 05-20-2004, 09:04 AM
YEP!!!!!
THANK YOU VERY MUCH!!!!!!!!!!!
Old 05-20-2004, 09:12 AM
rtypec's Avatar
Here's a spring chart done by Ling:
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Associated
White 40.00
Yellow 31.91
Purple 30.30
Copper 23.26
Red 23.08
Gold 18.35
Blue 16.53
Silver 13.89
Green 11.43
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Courtesy of Ling Kang Tong, Mechanical Engineer
ALZA Macroflux Development
rtypec is offline
Old 05-20-2004, 07:36 PM
evaa's Avatar
cant seem to upload a word document, the spring rates are in word in my computer.
evaa is offline
Old 05-20-2004, 07:38 PM
TimPotter's Avatar
Trader Rating: 15 (100%+)
Cut and Paste ....
TimPotter is offline
Old 05-20-2004, 07:48 PM
evaa's Avatar
here goes...
LOSI SPRING RATES
LOSA5108 1 Spring 20.0 Rate (Purple)
LOSA5110 1 Spring 25.0 Rate (Black)
LOSA5112 1 Spring 30.0 Rate (White)
LOSA5114 1 Spring 35.0 Rate (Orange)
LOSA5115 1 Spring 40.0 Rate (Yellow)
LOSA5117 1.15 Spring 7.6 Rate (White)
LOSA5118 1.15 Spring 8.6 Rate (Orange)
LOSA5119 1.15 Spring 9.6 Rate (Yellow)
LOSA5120 1.15 Spring 10.6 Rate (Pink)
LOSA5121 1.15 Spring 11.6 Rate (Red)
LOSA5123 1.15 Spring 12.6 Rate (Silver)
LOSA5125 1.15 Spring 14.6 Rate (Blue)
LOSA5126 1 Spring 17.5 Rate (Dark Green)
TC3 and Nitro TC3 Springs
Green 3941 12.000 lbs Softest
Silver 3942 14.500 lbs Softer
Blue 3943 17.000 lbs Soft
Gold 3944 19.500 lbs Medium Soft
Red 3945 22.000 lbs Medium
Copper 3946 25.000 lbs Medium Firm
Purple 3952 30.000 lbs Firm
Yellow 3953 35.000 lbs Firmer
White 3954 40.000 lbs Firmest
XRAY SPRING CHART
YELLOW super soft 14 lbs.
WHITE soft 17.5 lbs.
BLUE soft-medium 22.5 lbs.
VIOLET medium 28 lbs.
PURPLE medium-hard 33 lbs.
RED hard 38 lbs.
wow, that was easy
evaa is offline
Old 05-20-2004, 10:41 PM
tornado
Guest
Posts: n/a
Originally posted by nnick
The correct link is
Nick
arigato gozaimas
Old 05-21-2004, 10:37 AM
jeepnyy's Avatar
Check this link......so far the easiest I have found::::
http://www.deccosoftware.com/forum/tech/SpringRates.htm
jeepnyy is offline
Old 06-02-2004, 09:57 AM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Are the Yokomo springs the same size as the AE and Tamiya springs?
Jon Kerr is offline
Old 06-02-2004, 11:27 AM
Rob Mincey's Avatar
Anyone know if springs from companies other than XRay are compatible with XRay shocks?
Rob
Rob Mincey is offline
Old 06-02-2004, 02:16 PM
jeepnyy's Avatar
As long as they have the same diameter, they should work fine. Invest in a good digital caliper. It will be your best equipment for measuring.
jeepnyy is offline
