Old 06-17-2010, 11:08 AM   #1
Default CC Blower on Novak Ballistic?
Hey guys. I'm running a Novak Ballistic and LRP TC Spec in my FT Tc4. I'm looking to get more performance (top end). I have two fans on it on my own rig. I can't just zip tie them. One of the fans is a new Novak clear fan. The other one is a Muchmore Racing fan that has about two of the little fan piece things missing. The Muchmore fan still puts out more air than the Novak, and the Novak is new. I'm geared as high as i want to go. I get about 170 degrees on a 6 minute run. I can't gear any higher. I was thinking about getting one of those CC Blowers. They look like they put out more air, will be a better rig than what i have going, and will eliminate the need for two fans and cut down on the power going to the fans. Also looks like the teeth of the fan won't get broken as easy. Looks good all the way around. From the description though, it says - "intended for use with Neu-Castle 15 series motors, as well as motors that have outside diameters between 1 1/2" and 1 7/8". " I found that the outside diameter of the Ballistic is 2.07" x 1.41". That means it won't work, right?? Or would it stretch a little? Or is there another solution that will lower my temps so i can gear up?
By the way, mods, you can move this thread to the rookie section if you think thats where it belongs.
Dan
Dan Fowler
Getting out of the hobby... Check out my for sale thread.
TC4Racer123 is offline   Reply With Quote
Old 06-17-2010, 12:14 PM   #2
Jochim_18's Avatar
Fully advancing the timing on your motor will give you more top end but check your temp often but you better off getting another speedcontrol if your running stock 17.5 or 13.5 if you want to be competitive.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-17-2010, 01:09 PM   #3
I think its all the way up. So is the timing on the speedo. I would love a new ESC, just don't have the money right now. Trying to make small improvements as well as practice and improve my skill. I'm running 17.5 novice. Do you have any idea about the CC Blower though??
Dan Fowler
Old 06-17-2010, 09:11 PM   #4
Bump. Any input guys??
Dan Fowler
Old 06-17-2010, 11:00 PM   #5
Jochim_18's Avatar
It will make the motor more efficient due to the motor will run cooler but it will not make it fast...
Old 06-18-2010, 06:30 AM   #6
I know, i want to gear after i get my temps down..
Dan Fowler
Old 06-18-2010, 12:19 PM   #7
clparsons123's Avatar
well if you are still running novice why worry about speed? you should learn to get around the track first . but that is my opinion
EAM (TEAM EA MOTORSPORTS),ORCA, RC AMERICA, XRAY,HUDY,EZ CUSTOMS, RSD (REFLEX RACING) , JEFFS RC STUDIO, RCTVLIVE
Cory parsons
clparsons123 is offline   Reply With Quote
Old 06-18-2010, 12:49 PM   #8
What about your car setup? What track size do you have? If it's a small track, forget about top speed and work on making the car faster through corners. It will give you far better lap times than a few 10th's on one piece of small straight
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 06-18-2010, 05:33 PM   #9
Its got a long strait, and i'm loosing time there. Theres also some very technical sections, but i'm doing ok there. I can get around the track OK. I haven't practiced too much on the new layout, but my lines are getting better. But does anyway, does that info mean the 'blower' won't even fit??
Dan Fowler
Old 06-18-2010, 06:01 PM   #10
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Dan,are you talking about adrenaline,its not a big track and to add what cory said,stock class it is changing.you need to come out when we/there is racing
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-18-2010, 08:33 PM   #11
I know. I haven't been out there in forever. Now schools out, i'll be down there more often. And what do you mean stock class is changing?
Dan Fowler
Old 06-19-2010, 04:59 AM   #12
20 SMOKE's Avatar
stock 17.5 is slowing down,you cant gear the lrp TC spec to be as fast as a tekin,SP/HW, as they have more timing in the esc
Jamie W
Old 06-24-2010, 08:30 PM   #13
My ESC is all the way advanced. Its on 8 of 8. Keep in mind, its a TC4 I'm running; it has a really big internal drive.
Dan Fowler
