Old 06-14-2010, 04:17 PM   #1
Suspended
Trader Rating: 86 (100%+)
Default 13.5t gear ratio for tekin rs
hello, i m new to tekin esc and i am not quite sure how to set up the esc and the right gear ratio for tekin rs that use 13.5 epic duo 2 motor.
this outdoor asphalt track has about 120 feet of straight
i used x ray t3 with timing boost 30 turbo boost 7, 108 spur and 42 pinion and the motor temp is around 110f after 10 min of run time
any help would be apprieciated
littlealex is offline   Reply With Quote
Old 06-14-2010, 04:27 PM   #2
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
This is all you need:
http://www.rctech.net/forum/electric...-sensored.html
/thread
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-14-2010, 04:51 PM   #3
locked's Avatar
I'm a bit of a newb, but your FDR sounds way too low to me. Most 13.5 setups I've seen for a Tekin RS running Vegas 2.03 use a FDR anywhere between 6.5 and 8. If I calculated it right, your FDR is currently 4.885 (108/42 X 1.9)
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 06-14-2010, 05:32 PM   #4
Suspended
thanks for the info. is that mean i will need smaller pinion?
Old 06-14-2010, 06:08 PM   #5
Danny-b23's Avatar
Yes. I would try somewhere around a 24t pinion with that spur. This will give you an FDR of 7.34.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 06-14-2010, 06:17 PM   #6
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
he has low timing(37 total) where everyone else is 60-70
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-14-2010, 07:23 PM   #7
Suspended
just wondering how do you calculate gear ratio?
how should i set my timing? will too much timing shorten motor life or cause motor heat up faster?
Old 06-14-2010, 11:29 PM   #8
Suspended
anyone wanna help out a newbie please?
Old 06-15-2010, 10:06 AM   #9
locked's Avatar
Final Drive Ratio can be calculated like this: Spur divided by Pinion multiplied by Internal (drivetrain) ratio
The Drivetrain Ratio (also called the internal ratio) on a T3 is 1.9. Drivetrain ratio is the number of teeth on the differential/spool pulleys(38 for a T3) divided by the number of teeth on the layshaft pulleys(20 for a T3).
So for your car the formula is:
Spur/Pinion X 1.9 = FDR
Dave Locke
Old 06-15-2010, 11:39 AM   #10
Suspended
apprieciated for the info. now i know how to get the right gear
also wondering does people use smaller spur and bigger pinion for boost applications?
Old 06-16-2010, 04:50 PM   #11
Use this site to choose your gearing http://www.gearchart.com/index.cfm?f...n=chart.create just select Xray t2 and change the transmission ratio to 1.9.
p.s. turn your pc volume down
BILKO1 is offline   Reply With Quote
Old 06-17-2010, 04:14 AM   #12
You need to have a read through the Tekin RS thread. I know there are hundreds ofpages, but if you pick a spot in the last few months and read 3 or 4 pages, there will be good info on what you want to know.
Everyone has to do it, there is no absolute right answer, you just need to look around and start trying things out
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 06-17-2010, 07:54 PM   #13
Suspended
alright, i will do my study and try different gears and post my result here
Old 11-30-2012, 03:33 AM   #14
snuvet75's Avatar
Trader Rating: 16 (94%+)
Nobody really answers his question. I was also looking for right FDR for 13.5T w/ no boost. If he uses 4.8 FDR and yet the motor temp is 110F, it should be fine with that. He has to check ESC temp too. I would be alarmed if either of them goes above 150F. Manuals usually say ok till 180F but I would keep it down below 160F for both of them.
e.g. My set up for 17.5T blinky Xray T3: FDR: 3.8(S96 P48)
10.5T with timing boost 50, turbo7: FDR: 5.29(S78 P28)
For both, I was able to keep the temp below 150F.
It can vary greatly depending on his driving skill. If he sucks at driving bumping into other cars, walls, using a lot of brakes, going full throttle every corner, then he'll be seeing a lot higher temp than I do when using the same FDR.
I'll probably go with 4.8 FDR with 13.5T blinky first and work my way up or down. BTW, I'm using Tekin RS as well.
snuvet75 is offline   Reply With Quote
Old 11-30-2012, 08:56 PM   #15
Trader Rating: 20 (100%+)
13.5 no boost 4.5
13.5 boost 7.0
these are good starting points
goots is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 10:06 PM
