Old 05-18-2004, 06:28 PM   #16
edseb's Avatar
Correct, and when discharging it is better to discharge at 30 amps cause that more closely replicates the discharge rate when racing so you can see how the batteries are performing. Most chargers, dischargers will give you info and you want the info when discharging at 30A.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-18-2004, 06:59 PM   #17
JDXray's Avatar
Send a message via AIM to JDXray
thank you all for clearing up my question. So i can use any 12 volt power supply to discharge at 30 amps.
JDXray is offline   Reply With Quote
Old 05-18-2004, 07:06 PM   #18
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
The amps of the PS doesn't matter as much durring the discharge as long as it has enough to power the charger.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 05-18-2004, 07:10 PM   #19
any comment in PITBULL X3? How about the charging performance compare with turbo series.
Loman is offline   Reply With Quote
Old 05-18-2004, 08:51 PM   #20
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
clinttredway
if u had to discharge at 14 amps then something is wrong with your charger... the dischage mode does not require a higher power supply...discharge mode does not draw from the power supply in an amp reading.. it does it in volts...
i have a t 30 and i use a novak n power 10 amp supply... i have never had a single problem and i discharge at 30 amps every time... your power supply rating it based on your charging amps. and the motor draw... if u run motors u want to have 13amp or ;arger supply.. because a motor can pull that many am,ps...
ce manual says they recommend i belive 14.5 amps...
burbs is offline   Reply With Quote
Old 05-18-2004, 09:08 PM   #21
clinttredway's Avatar
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
I guess I was reading it wrong... oh well.. I still have a good power supply now
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 05-21-2004, 01:29 PM   #22
JDXray's Avatar
on gfx do you put both postives and both negatives on a battery? And it can only charge one battery right? Also for motor run-in which plugs do you use, the small or the big or both?
Old 05-21-2004, 02:50 PM   #23
Tres's Avatar
Use the big ones, the small ones are only used durung cycling.
http://www.competitionelectronics.co...20op%20ins.pdf
Tre's
www.tnt-fx.com
Old 05-21-2004, 03:04 PM   #24
JDXray's Avatar
Thanks tres.
Old 05-21-2004, 03:25 PM   #25
Hi,
I have a Turbo 35 GFX and a 12.5 amp power supply, my charger will discharge at 30amps off of this power supply.
Cheers,
Sam.
Sam Contarino is offline   Reply With Quote
Old 05-21-2004, 03:28 PM   #26
JDXray's Avatar
yes i think we already clarified that, if you look page i think 1-2 pages. ( Check page 4 )
Old 05-21-2004, 03:48 PM   #27
jeepnyy's Avatar
Way to go JD.....when in doubt...check the manual. They are written in a simple easy to understand way......to clarify things in more detail ........post your question.....someone knowlegeable will provide an answer (hopefully, no speculation)....
HAPPY RACIN'
GO FAST..............TURN LEFT...........
jeepnyy is offline   Reply With Quote
Old 05-21-2004, 05:13 PM   #28
burbs's Avatar
actually i use mt voltage leads always... they are meant to read the voltage more acuratly... not just during cycling if u dont use them when u charge it will not peak at the proper reading to.. i know where talking minimal difference,, but as competitiive as most are .. i t would matter..
Old 05-21-2004, 05:22 PM   #29
Send a message via AIM to R/C Anonymous
if you look at the voltage on the T35 with and without the small wires connected there is a difference for charging and discharging...i use those wires for both
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 05-21-2004, 09:09 PM   #30
ottoman's Avatar
I asked Jim Baily (co owner of CE) about the small leads and he said they are only used for discharging and wont affect the charging of a batt.
ottoman is offline   Reply With Quote
Competion Electonics turbo 35bl stealth ed, turbo 30, Pitbull x3 & Novak Millenium Pr pablo101 R/C Items: For Sale/Trade 29 10-27-2008 09:44 AM
Competition Electronics Turbo 35 BL stealth Edition And Turbo Flex 30 NIdaho Mudder R/C Items: For Sale/Trade 1 06-10-2007 07:55 AM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 10:10 AM
Wanted, metal lathe, milling machine, Turbo matcher, turbo Zapper lazarus Other Items: For Sale/Trade or Wanted to Buy 1 05-15-2003 12:20 PM
Tunning issue with MR12 turbo and RD turbo pipe PG Nitro On-Road 12 05-05-2003 10:19 PM
