Old 05-17-2004, 05:03 PM   #1
Send a message via ICQ to Kai_Fuller
Default Electric Motor Brushes coming loose...
I recently dusted off my ol' original RC10T truck for a spin, removed the brushes for inspection, as far as I can tell were good to go (at least for a little driveway driving)... After re-installing them they seem to come loose after the slightest jiggle, and the motor stops running.
I never thought much about how the springs went in, could I be installing them wrong? The hook side is down, and the flat side in going into the little tab... But it doesn't seem to hold the bush in there securely. Or is it simply that the spring has lost tension?
1.) Is there a "improper" and "proper" way to install the sping.
2.) Will the sping loose enough tension over 10 years that it will allow the brush to loose contact???
Kai_Fuller is offline   Reply With Quote
Old 05-17-2004, 05:08 PM   #2
Tek Nickal's Avatar
Maybe the brushes are so worn down that the spring has very little contact and not providing enough tension to hold the brush down to the comm.
Tek Nickal is offline   Reply With Quote
Old 05-17-2004, 05:30 PM   #3
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: Electric Motor Brushes coming loose...
Kai - Pull the motor out of the truck to inspect it. Pull back on the brush shunts, and let go. You should hear a nice "snap" as it pushes back against the com. If it barely sets back in, they definately need to be replaced. The springs could have worn out, or the brushes could also be to short, and need replacing too.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-18-2004, 03:32 AM   #4
The brushes might be sticking in the brushhoods because of dust or dirt. Clean everything out and try again. If the brushes are free but still do not make contact they might be too short.
andsetinn is offline   Reply With Quote
Centax 2 nut keeps coming loose cmego Nitro On-Road 6 07-24-2008 01:12 AM
Electric Motor Brushes? YokomoMR4BX Electric Off-Road 10 01-18-2007 04:30 PM
Mid Screw Coming Loose on HPI 28 Motor SpeedChair Onroad Nitro Engine Zone 2 07-11-2005 10:39 PM
My flywheel is coming loose help. Smoke21 Nitro On-Road 10 01-16-2004 06:22 PM
