ESC Suggestions
ESC Suggestions
Im running in a "beginner" class for VTA. We run a 20t stinger motor and a 4-cell battery. Any suggestions on the best ESC to run? Thanks
Grant.
Grant.
Those are all important questions in order to lead you in the right direction.
Grant, there's all sorts of good esc's out there. Do you want to find a used one ?? Do you want reverse function?? Will you be changing to a brushless motor or Lipo battery any time in the near future ??
Thanks. New or used it doesn't matter. In trying to stick to a budget but I also want to be fast. We are not allowed to use reverse the reverse function is not important. As far lipo and brushless, yes, I do hope to move up to the VTA class at some point ... when i don't know, depends how well I get a hang of things.
On the used end it's wide open if you just want something good for brushed motor/no reverse and no lipo. Personal choice is the Tekin G12C3. Plenty of used ones out there, top of the line performance and pretty darned bulletproof. Not the smallest of esc's but it also doesn't require a ballast can.
Novak GTB or GTX is good. LRP Quantums......and a bunch more !! Best bet is to stick with the big 3 companies...Novak, LRP and Tekin. Especially for the older brushed only esc's. You can find any of these on Ebay or here. Good Luck and yell if we can help.
