Old 03-04-2006, 05:08 PM   #466
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Originally Posted by rinkrat99
Hi Chris
I figured out the Excel thing! The file only stored a few parameters; Vpack, Vcells, Time and FallBack
Is there anything else that is needed?
Hi, yes it seems like you are missing a lot of info, you should get the volts for each cell, fallback for each cell, basically everything. Send me the .ptm file and I'll check it out.
[email protected]
crimson eagle is offline   Reply With Quote
Old 03-05-2006, 07:45 AM   #467
radio_car_racer's Avatar
Originally Posted by crimson eagle
Wow I'm out of date. Where did you get that?
from Phil
radio_car_racer is offline   Reply With Quote
Old 03-05-2006, 08:56 AM   #468
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Everyone keeps saying that Phil has the new version but is it posted somewhere? Can someone email it to me?
rinkrat99 is offline   Reply With Quote
Old 03-06-2006, 12:49 AM   #469
try this link. PT software
not sure if it's v1.5.6 but it's just downloaded OK
Old 03-06-2006, 07:29 AM   #470
rinkrat99's Avatar
Its version 1.5.5.
Old 03-06-2006, 12:39 PM   #471
Grenade10's Avatar
Trader Rating: 37 (100%+)
Loan a charger to Rinkrat99 and look what an EE is digging into!!!
Crimson Eagle, He has my new 30 amp unit you got to me this fall. Unit has worked great, and charging has keep me on the battery power with the 3700's. I'm off to run 1/8 gas this summer, so loaned the charger - thanks for all the help.
Come fall, it'll be ready for some new cells, so I hope you get a chance to play with the 4300's
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-06-2006, 06:54 PM   #472
rinkrat99's Avatar
Look who wrote an response back!
Now Grenade when Chris gets me the right software there is no stopping me from gathering data!
Chris if you want to try some HOT motors, try the Integy Matrix 19t (Atlas based) and the KOS27 Stock!
Rinkrat
Old 03-07-2006, 07:02 AM   #473
Rinkrat
Thanks I'll give them a go after I get the Nats out of the way.
Anyone coming to the Nats?
Chris
Old 03-07-2006, 10:11 AM   #474
rinkrat99's Avatar
Hey Chris
If you are running the same level of software, that does not explain why I am not getting the full data set.
Any suggestions?
Old 03-07-2006, 12:36 PM   #475
I have a bare bones old laptop I use for my testing which I think is the latest version. I just don;t have the actual install program for the latest version. I had it on a usb flash drive but that died on me a month or two ago.
Chris
Old 03-19-2006, 10:44 PM   #476
kiyano's Avatar
1.5.6 is almost the same as 1.5.5. One difference is that 1.5.6 has the function to avoid the error by TIMEZONE. However, this does not affect the user of the United States or Japan.
runtime error may be generated when your PC runs short of DLLs. Please download runtime from microsoft, supposing you encounter runtime error.
http://www.microsoft.com/downloads/d...DisplayLang=en
Thank you,
Kimihiko.
Kimihiko Yano
http://www.kimihiko-yano.net/
kiyano is offline   Reply With Quote
Old 03-20-2006, 04:27 PM   #477
Trader Rating: 17 (100%+)
Ok Chris, I have a slight problem here. Saturday at the race track I went to slide my charger over (touched the side of the case) and got zapped by it (no wires were crossed or anything shorted out externally as far as I could see). I looked at the screen on the Protrak and all I seen were vertical lines on the screen (see picture). I then checked my other charger that was hooke up to it to see if that got messed up, but it wasn't. What can I do or check to correct this problem? Any help would be appreciated. I called and left a message on your machine. Thanks!
429racer is offline   Reply With Quote
Old 03-20-2006, 05:48 PM   #478
Hi,
Thanks for the pic, as we discussed on the phone I'm working on it and I'll let you know as soon as i find anything out.
Chris
Old 03-20-2006, 06:33 PM   #479
Excellent Chris! As always it is a pleasure to talk to you.
Old 04-05-2006, 08:09 PM   #480
should of been pm
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 10:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 11:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
Pro-Trak CRASH Electric On-Road 38 03-15-2002 10:30 PM
