Old 02-27-2006, 11:36 AM   #451
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Originally Posted by Merciless
Guys just recieved my new V.10.83 Pro-Trak
One quiery though, When using Version 10.70 software on the pc and doing a discharge only when the Pro-Trak cuts off at the end and i presume sends the final data to the pc i get a "runtime error 711" ??
I have to click OK to clear this and that shuts the monitor program down and i lose all the data
Anyone got any ideas on the problem ??
I have even tried re-installing my WinXP operating system incase there was a problem there.
Oh i was not getting this with my OLD 10.5* version Pro-Trak i swapped in, if that helps at all ........
Cheers
Rod
Call Phil,
He has a fix for this I'm told.
Chris
crimson eagle is offline   Reply With Quote
Old 02-27-2006, 12:56 PM   #452
Merciless's Avatar
Send a message via ICQ to Merciless
Originally Posted by crimson eagle
Call Phil,
Chris
Thanks Chris,
Since no one had posted earlier i have done this a got the files.
2 .exe files to install and all fixed
Merciless is offline   Reply With Quote
Old 03-02-2006, 10:01 PM   #453
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Where can I get the 2 fixed exe files? I ran into the same problem
rinkrat99 is offline   Reply With Quote
Old 03-03-2006, 03:24 AM   #454
radio_car_racer's Avatar
Call Phil,
Chris
anyone got a fix for this error?
spoke to Phil and he's not seen it before
I'm running XP home, running IE via cable modem, other programs running whilst using PT software. I'm not using copy & paste functions whilst PT monitor is running.
radio_car_racer is offline   Reply With Quote
Old 03-03-2006, 05:05 AM   #455
kiyano's Avatar
This is the error resulting from windows OS. When OS error occurred,
previous monitor program was ended even if the test is in progress.
In order to avoid this, when OS error occurred, this dialog is displayed
and the test was continued. When this dialog is displayed, data is not
displayed on a screen. However, data is saved internally. If pro-trak finishes
discharge, please save data by a monitor program. And please terminate a
program once and start again. And please open the saved file.
This problem may be avoidable by changing a setup of monitor program.
1) Interval --> set Manual (default)
2) PC Spec --> Low (default)
3) Do not push "update" button superfluously.
Thank you,
Kimihiko.
Kimihiko Yano
http://www.kimihiko-yano.net/
kiyano is offline   Reply With Quote
Old 03-03-2006, 05:21 AM   #456
Kimihiko.
Thanks Kimihiko,
I have all the data saved OK
will try 1 & 2 above and report back (can't recall doing 3)
Old 03-03-2006, 08:56 AM   #457
rinkrat99's Avatar
Hi All
For some reason the only downloadable version of the graphing software is 1.5.5
Can someone point me to the right place to download that and also the Terminal.exe application
Old 03-03-2006, 10:34 AM   #458
Originally Posted by rinkrat99
Hi All
1.5.5 is the version i have, I am not aware of a more up to date version. The Terminal.exe program has been available on the Pro Trak website which is in my sig. I will check to see if it is still there though.
Chris
Old 03-03-2006, 11:12 AM   #459
rinkrat99's Avatar
Hi Chris
I get the same Runtime 711 error on discharge only. I thought the version Kiyano had in his reply on page 1 of this thread looked differently.
Old 03-03-2006, 11:13 AM   #460
rinkrat99's Avatar
Chris
I also do not get any info in the box at the upper right corner of the app. It would be nice to be able to export this data into excel
Old 03-03-2006, 11:25 AM   #461
Chris
I'm running 1.5.6
Old 03-03-2006, 11:33 AM   #462
rinkrat99's Avatar
where can I get that?
Old 03-03-2006, 12:45 PM   #463
Originally Posted by radio_car_racer
I'm running 1.5.6
Wow I'm out of date. Where did you get that?
Old 03-03-2006, 12:48 PM   #464
Chris
You don't export to excell you import the file into excell. I have done this a lot. In excell when opening file make sure it's looking at all types then select the file. It will give you some opening options, select comma and delimited. You can do all kinds of crazy stuff with the data from there as you can tell from my IB / GP tests.
I'm really looking forward to getting my mitts on some 4300's
Old 03-03-2006, 02:22 PM   #465
rinkrat99's Avatar
Hi Chris
I figured out the Excel thing! The file only stored a few parameters; Vpack, Vcells, Time and FallBack
Is there anything else that is needed?
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 10:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 11:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
Pro-Trak CRASH Electric On-Road 38 03-15-2002 10:30 PM
