Old 11-11-2005, 04:34 PM   #421
Hi Radio_car_racer,
It sounds horrible. I did experience a similar case before on a 2-nd hand pro-trak. Did your unit is a brand new 5-month old baby? BTW would you pls tell me what is "adjust the pot"? In my case, I finally replace the discharge fet and the problem solve.
mr4-tc sp is offline   Reply With Quote
Old 11-13-2005, 06:48 AM   #422
radio_car_racer's Avatar
Originally Posted by crimson eagle
Hi Radio,
Those numbers sound a little high, you might want to ask Phil to check your discharge rate. Try equalising first and see what you get in on Charge. My new 3700's fully equalized is right qround 4400.
Chris
Spoke with Phil and he is thinking it's software issue when on 4 cell rather than a discharge current fault. Running a 6 cell pack @ the mo so will report back soon.
All
using L/Hp/L @ 6/7/6 with 800/3000 lockouts & 40% Hp
results of 6 cell pack. discharge now less than charge cap
Charge Type : Linear
Charge Amps : 6.00A
Number of Cells : 6
13:43:34 Full Discharge B4 chg
14:29:15 D/CAP TIME SPREAD PV1 AV1 AVE POWER% MATCH% E/VOLTS PEAK/V F/PEAK F/BACK CCAP
PACK#02 3800 456 19 6.98 7.231 7.045 99 92 5.53 9.13 0.03 0.03 4065
CELL1/ 2 3841 460 3 1.16 1.207 1.176 100 98 0.98 1.52 0.01 0.01 4065
CELL2/ 2 3858 462 1 1.17 1.206 1.179 100 102 1.02 1.52 0.01 0.02 4065
CELL3/ 2 3808 456 7 1.15 1.196 1.165 99 95 0.95 1.53 0.02 0.01 4065
CELL4/ 2 3858 462 1 1.16 1.207 1.179 100 104 1.04 1.51 0.01 0 4065
CELL5/ 2 3708 444 19 1.16 1.195 1.153 100 50 0.5 1.52 0.01 0.01 4065
CELL6/ 2 3866 463 0 1.15 1.188 1.16 100 101 1.01 1.52 0.01 0.01 4065
radio_car_racer is offline   Reply With Quote
Old 11-13-2005, 08:49 PM   #423
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
RCR,
That looks better, definitely more realistic. I was racing 12th 19T today and I was putting 4300-4400 in on charge but I equalize my cells for about 5 hours before I race.
Let me know what happens with the 4 cell problem, I never seen that one before. What version of the software are you running?
Chris
crimson eagle is offline   Reply With Quote
Old 11-14-2005, 12:30 PM   #424
PT is 10.82v
Phil should be @ Teesside this weekend for the 12th National. He may have a revised rom by then to try
Old 11-14-2005, 12:48 PM   #425
RCR,
I just slapped in a 10.82 this weekend, I haven't done a discharge yet though.
Last time I talked to him he wasn't sure if he was going to get an entry. Hopefully he can slide in. I'm expecting calls and e-mails about 12th setup this weekend.
I ran 19T 12th yesterday with my T-fource, was good but the T-fource pushes a little too much on the rug for my liking.
Chris
Old 11-14-2005, 01:01 PM   #426
looks like he has an entry for Mod on Sunday with a reserve slot for Sat
see here, entry list bottom of page
Old 11-14-2005, 03:43 PM   #427
RCR,
I hope the mod guys don't frighten him off, Mod 12th can be scary..
Chris
Old 11-15-2005, 12:10 PM   #428
Our rules allow us to run 19t in Mod class which are not that far of the pace. Hope he runs the 19t you sent over with CRC. That way he'll spend more time on the carpet rather than in the pits repairing the car
Old 11-15-2005, 01:37 PM   #429
RCR,
I think we could run a 19T in mod too, and it isn't much slower you are right. Tell him if he puts new brushes in the Reedy I sent him to make sure the brushes are well seated before he runs it or it will feel slow. The reedy has a lrger com than normal. 767's should work fine once they are broken in fully. also with the 19 he won't have to worry about throttle management. Try running strapped for 8 minutes with a 9 wind.
Chris.
Old 11-23-2005, 12:48 PM   #430
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey Guys-
I can't seem to remember how to get to the screen that let's you set the maH per phase. Anyone?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 11-23-2005, 03:30 PM   #431
Jaybee,
It's in the settings menu look at the lockouts it will be in there. This function as I recall does double duty as a lockout in normal mode and as the changeover point when in MPCM mode. I'll double check tonight.
Chris
Old 11-23-2005, 05:34 PM   #432
JayBee's Avatar
I haven't figured it out yet
Old 11-24-2005, 08:36 PM   #433
Old 11-24-2005, 08:53 PM   #434
JayBee's Avatar
Sweet!!
Old 11-24-2005, 09:35 PM   #435
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Chris, you the man! Great license plate!
EA Motorsports
picco007 is offline   Reply With Quote
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 10:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 11:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
Pro-Trak CRASH Electric On-Road 38 03-15-2002 10:30 PM
