Old 03-04-2005, 08:03 AM   #286
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi Jaybee,
I'll answer in more detail later but my first thought looking at your pic. Do not put a fan on your cells, this is not a good idea. It is best to let your cells war and cool naturally without forcing the change in temperature.
Did you get a pack match here? looks like cell one may have cut the charge off but maybe not.
I'll be back later for mor in depth stuff
crimson eagle is offline   Reply With Quote
Old 03-04-2005, 09:56 AM   #287
Chris I have nt forgotten you shouild go out Monday.
John
John Malin is offline   Reply With Quote
Old 03-04-2005, 11:22 AM   #288
Thanks John, i know you are busy thats great.
Chris
Old 03-04-2005, 11:46 AM   #289
Ok Jaybee,
I may not get all finished here but I'll make a start.
Charge.
Capacity is ok, we talked about what seconds were on the labels about 420 I think you said so around 4000 is ok, you may find that goes up the more you equalise between charges. Temperature is a little on the high sode for me but I hear of higher than that.
The peak charge volts is good, this is shown in the power %age numbers though they do vary a bit from cell to cell.
Discharge.
A discharge spread of 10 seconds is pretty good really, not many of my packs are that close, I think my closest was 8 seconds but that was an old pack which I did not race with anyway.
If you look at the end volts you will notice that cell one was way down, the other being very close. This is confirmed by the seconds of cell 1 being the least at 381. You can interpret from this also that cell 1 went from 1.0v to .29v in 10 seconds which was the point of cut of for the last cell (cell 2) to hit 1.0v (or 0.99v). This is very fast which makes me think the cell 1 has the lowest IR and I'd think that this cell had the highest (or close to) pwr %age. I could be off here as I have seen some strange things.
Ok I see the individual pwr %ages at the bottom, yes cell one was up there but cell 2 is starting to look very good here, good run time good voltage and good IR. Great combination.
There is some interesting numbers for the pack at 5 minutes cells 2 and 5 are very interesting cell 5 looks like it has the best voltage throughout the discharge, cell 4 looks like it has great voltage at the beginning of discharge.
It's easy to see from the Discharge Capacity that cell 1 ia a little down on the rest, this is the cell which will determine how your pack performs for run time, when cell one is done you aren't going anywhere very fast. IF you run your car to a crawl it will e cell 1 that gets the most punishment and could have issues in the long run. This is an ok set of cells 2-6 are fairly close cell 1 is a little off. I probably would not switch them around though but I would keep my eye on cell one to see how it behaves.
Chris.
Old 03-04-2005, 09:01 PM   #290
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Thanks ALOT Chris.
We spoke earlier today about the next pack... here's the rundown on it. I'm prepared for the obvious 'BAD' news
CHARGE INFO
Cap.- 4075
Power- 100%
Time- 54:26
Pack Vlts.- 8.64
Peak Vlts.- 9.06
End Vlts.- 9.01
Temp.- 114-124 degrees
breakdown...
*Pwr. %'s
100 101 101
100 99 98
*Pack Vlts
1.41 1.41 1.43
1.41 1.43 1.44
*Peak Vlts
1.51 1.50 1.50
1.51 1.53 1.54
*Fallback
.01 .01 .02
.02 .01 .03
*False Peak
.01 .02 .02
.01 .03 .01
*End Vlts
1.50 1.49 1.48
1.49 1.52 1.51
DISCHARGE INFO
Time Cap. Dump
298 2491 46
Pack Match- 86%
Cell 6 worst- 63%
Pack Vlts @ 5min.- 6.59
Cell time spread- 42sec
Pack Vlts- 7.69
Peak Vlts- 8.71
End Vlts- 5.69
AV [email protected] 5min.- 6.93
AVE- 6.86
Discharge Capacity- 2491
Power- 104%
breakdown...
*Time
274 292 309
316 300 295
*Pack Vlts
1.26 1.28 1.28
1.26 1.28 1.27
*Peak Vlts
1.45 1.44 1.44
1.44 1.46 1.48
*Fallback
.00 .00 .01
.00 .00 .01
*False Peak
.01 .02 .01
.01 .02 .01
*End Vlts
.96 .99 1.05
1.01 .95 .70
*[email protected]
1.09 1.08 1.11
1.11 1.09 1.08
*AV [email protected]
1.13 1.15 1.15
1.16 1.14 1.14
*AVE
1.12 1.14 1.14
1.15 1.13 1.12
*Discharge cap.
2291 2441 2583
2641 2500 2466
*Power %'s
104 105 105
105 104 102
*Pack Match
87% 90% 95%
91% 86% 63%
*Cell Spread
42 24 7
0 16 21
this is my very first equalization/charge/discharge cycle; Chris what's your $.02?
Go ahead and give me the long version
- JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-04-2005, 10:09 PM   #291
JayBee's Avatar
Post Question...
How do you determine total run-time for the pack after charging?
- JB
Old 03-05-2005, 12:55 AM   #292
Total run time from charge capacity isn't so much a science as a general theory, the more you put in the more you get out but it does vary. Some cells have more losses during charge than other cells but the general theory is sound.
Chris.
Old 03-06-2005, 09:27 AM   #293
Hi all,
Some info added to my web site. A report on IR, peak volts and power %age: -
www.citlink.net/~kpngtrak/AR_IR_Pwr%25age.htm
Also The Pro Trak web site has a report on this with more back up data and some really good graphs.
www.pro-trak.co.uk
All very good stuff there.
Chris.
Old 03-06-2005, 09:57 AM   #294
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Great!
EA Motorsports
picco007 is offline   Reply With Quote
Old 03-07-2005, 09:55 AM   #295
Chris,
has anyone mentioned not getting the end results with rom version 10.77 and monitor version 1.5.2? I have been not getting the and results chart since my 10.77 rom upgrade. I saw that kimi has 1.5.5 but I cant see where to download it.
John
Old 03-07-2005, 01:04 PM   #296
Hi all,
I already talked to John, but if anyone esle having the same issues, you do need to new monitor program to run the latest Pro Trak software. You need to e-mail kimihiko and ask him for it.
Chris
Old 03-21-2005, 07:31 AM   #297
fire929's Avatar
Default Pro trak 30
Wher can you purchase and how much????????????
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 03-21-2005, 07:47 AM   #298
AlanLim's Avatar
Default Re: Pro trak 30
http://www.citlink.net/~kpngtrak/CDAT_Menu.htm
$450
AlanLim is offline   Reply With Quote
Old 03-21-2005, 08:06 AM   #299
fire929's Avatar
Default Re: Re: Pro trak 30
$450
Thnx
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
Old 04-05-2005, 08:15 AM   #300
Hi kiyano,
I have encounter a problem on both charge and dischage on a battery. No matter I charge or discharge a pack, it shows "Check external Fuse" error message after several seconds. I have read the previous post and know that it is about the disorder of the FET. But the case is only discribe the discharge. So
1. Does it also reflect that both discharge and charge fet were fail.
2. I know there is 3 "fet" type such attaching to the heatsink. I already known which one is the discharge fet, would you pls tell which one is the charging fet?? Is it the one on left the most???
Thanks?
mr4-tc sp is offline   Reply With Quote
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 10:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 11:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
Pro-Trak CRASH Electric On-Road 38 03-15-2002 10:30 PM
