Old 11-18-2004, 04:19 PM   #196
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
PaZ: email me at [email protected]
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 11-18-2004, 04:22 PM   #197
Send a message via AIM to galway
Originally posted by carkillaii
Can anyone tell me what the price's are for the Pro Trak 30 amp
thanx
if you go to the pro-trak site it is listed as 250 pounds which is about $460.
galway is offline   Reply With Quote
Old 11-18-2004, 04:24 PM   #198
picco007 - thanks for the reply, but I am looking for the pinout of the connector not what type it is.
I think I have given up hope of modifying my old ICS so if anyone is looking for one I am selling it cheap.
Also if anyone has a new ICS or a temp detect module I am looking for one.
Old 11-19-2004, 10:04 AM   #199
Hi all,
The newest version 10.72 seems work much better than before. Charging is better as it has a lower temperature. However did anyone figure out that it is unable to set the delta peak when charging and there is no pack match and pack assessment after discharge?
Thanks!
mr4-tc sp is offline   Reply With Quote
Old 11-19-2004, 11:31 AM   #200
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Hi Mr4
I must admit, I never changed the delta during charge so i have no idea if it could be done before. You are right in saying it cannot be done now unless I am missing something.
I'm running a cycle right now so I'll let you know about the other things you have asked about.
Chris.
crimson eagle is offline   Reply With Quote
Old 11-19-2004, 12:08 PM   #201
I just noticed you are right i dont see the pack match or assesment any more unless I am using the monitor program.
John
John Malin is offline   Reply With Quote
Old 11-19-2004, 12:37 PM   #202
I am getting my pro-trak back from upgrade tonight. I will check into missing features as well. It seems very disturbing that we would loose features.
Old 11-19-2004, 01:01 PM   #203
I have just finished running a cycle and get the same results. I have e-mailed Pro Trak and will let you know what he tells me when I find out.
Chris.
Old 11-20-2004, 09:46 AM   #204
Hi all,
In the web page "www.pro-trak.co.uk', they describe CDAT in 10.72 could toggle reference charge with different charge types. However I found only a function call "S.A.L" in my newest ROM(10.72). In function S.A.L. I just only about to toggle between different cell types. Would you pls. tell me how to use this function? Thanks!
Old 11-20-2004, 10:04 AM   #205
Hi All,
I spoke with Pro Trak today and have some answers for you. The short answer is, some meaningless results were eliminated so you would not get a false impression of your cells. The best way to explain this is by an example.
Given a discharge cut off of 1v per cell this is the end volts at the end of discharge.
cell 1 .95
cell 2 .50
cell 3 1.03
cell 4 .86
Cell 2 has hit .5v, this triggers the Pro Trak to stop the charge
Cells 1,2 and 4 have gone past 1v, the count for those cells have been terminated and recorded when they hit 1v (which you specified). Cell 3 has not got to 1 volt it's numbers cannot be recorded to the 1v point therefore any match numbers given will be innaccurate.
Up to this version the pack match has been an average of the percentages from each cell. with a 1v cutoff cell 1 would be 95% cell 2 50% etc. When you have one high cell and one low cell they will tend to average each other out and you will get a false indication of a reasonably matched set of cells.
The higher you set the cut off point, the more likely it is that the cells will all reach that point before the first one gets to 0.5v. However, the higher the cutoff the lower the total capacity of the pack will be. My thoughts about this is - Your pack is only as good as your weakest cell - When your weakest cell is done you aren't going to be getting much speed in your car on the track. Therefore any extra time, in the other cells is worthless.
If you have any questions please ask.
Chris.
Old 11-20-2004, 11:26 AM   #206
Hi all,
just to prove the point I ran another cycle with the cut off set to 1.1v which is very high. all of the cells went past 1.1v before the first cell hit 0.5v and the pack match and assessment were given. In this case one of the cells was at 68% and the others were at around 95%. At 1.0v cut off 0.5v before all of the others get to 1.0v, this terminates the charge early. This does surprise me actually as this set is very new, maybe 8-10 cycles on them. I expected a better match.
Chris.
Old 11-20-2004, 01:41 PM   #207
PaZ
PaZ's Avatar
Tres- Thanks ill e-mail you
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-20-2004, 11:35 PM   #208
anyone know the us price for this charger.
gotyournumber is offline   Reply With Quote
Old 11-21-2004, 01:25 PM   #209
PaZ
PaZ's Avatar
its 250 in the UK so i would getimate at around 450-500 i think im not good with currency but i think its 1 dollar = 1.8 or 1.7 i think
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-21-2004, 06:48 PM   #210
Hi Chris,
Thanks a lot!!! I have tried again on it and I think mine are not that match. I also visit the web site "www.pro-trak.co.hk". Phils has post the newest info on that. It is a better than before as I used to get a good match even there is a dead cell.
I also have tried the S.A.L. to monitor the old ICS. Of course it could not bin into the CYCLE function. It still able to give out a audio signal on it. A very nice feature that I could monitor others low-end equaliser tray!
Thanks a lot!!!
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
Pro Trak 30 crimson eagle R/C Items: For Sale/Trade 0 11-12-2004 10:51 AM
Pro-Trak BMS Glenn Atterton R/C Tech Site Forum 1 11-21-2003 11:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
Pro-Trak CRASH Electric On-Road 38 03-15-2002 10:30 PM
