RCGT....Where is it at now?
#361
You can use 24mm tires on 26mm rims with no problem. Back when we had to glue tires to race this was something we would do as a tuning option. It makes the tire lower profile like Charlie said. Some tires worked better on 26mm rims...sorex and Yokomo tires were the better on 26mm rims then 24mm. So its not unheard of to do this. If you were around Sedan racing when it was huge ie late 90's this was common place to do. So yeah you could spec a Sorex 36 and insert and say what ever 26mm rim you want to keep the cost lower because the tires will last that much longer.
to bad Yokomo doesnt still make the 206 line of tires....they were like 5 bucks a pair and worked well on carpet and asphalt.
#362
Trader Rating: 32 (100%+)
If they can use superglue and use a rubberband to assist them then there shouldnt be much of an issue. After the first set they will get the hang of it....we all started someplace. Its really not much different then mounting 26mm tires on 26mm rims.
#365
Just my opinion at this point....
Our RCGT class is limited (5-6 guys), and really don't see the numbers picking up the way we like to see them, but I don't think opening up the wheels and tires will help much in our case.
We're pretty much staying the course and running the current guidelines with the X-Patterns this season.
I'll be interested to see if any of you other guys make a tire/wheel changes and see if it helps.
I think by continuing to offer an RCGT class will be the key to getting more racers onboard....eventually.
The more spectators and casual racers see how cool this class is, the better the chance that they will jump in.
I also think that as long as we all embrace the concept of RCGT, by the body styles, limited power, and realistic wheels and tires, we can still tweak the guidelines a bit, to suit each individual program.
Most of our guys are already locked into VTA and Nitro VTA, so we also have to look for new racers all the time, for RCGT.
RCGT is still a great class, and looking to still build upon it....
Can you say Deja Vu !! Surprising that almost all of this was discussed before....except tires.....in 60 pages of comments there was very little negativity about the x-patterns. Then again...nobody made a splash with a $15 tire set. It was great reading all of the enthusiastic comments from less than a year ago. Just makes me think that RCGT started as a good program. It still is. Maybe a couple things need to be updated since so much has changed but it's still a great program.
#369
But regardless, it looks like we're back to the burning topic: cost. What Sorex tire is equivalent to the HPI X-pattern: the 28, 32, or 36?
#371
I really believe that deviating from the x-patterns for open tire is opening a can of worms and people quite possibly will have to start buying one run tires to accomodate the track. That or people will start buying the tire of the week.
Also I don't see where this excessive wear is coming from, the only time I've seen a pair get mauled is from using turbo and boost. By me the rules as they stand seem to work fine. Also a few pages back there was a set of 26mm tamiya tires that weren't any cheaper than the x-patterns.
#375
The Citrik system is not slow,pretty good
