Like Tree4Likes
Yokomo R12
Old 10-10-2015, 09:18 PM
  #841
choisan's Avatar
thanks for the info. but i feel bad about they dropped the "old" wheel. the r12's wheel to me seems to be the offset of honda's car versus toyota's car. the bigger the offset number means the hub point is more at the end of four corner, contributes more grid
and yokomo finally compromised its design
choisan is offline
Old 10-11-2015, 04:02 PM
  #842
I now have a offset hub that will fit the Yokomo so you can run my offset wheels.
www.proonerc.com go to catalog. My wheel has a 19mm offset similar to the Yokomo wheels.
Steve Dunn
sdunnmcp is offline
Old 10-11-2015, 06:26 PM
  #843
JimmyMac's Avatar
Steve Dunn
A few racers at our track run those. Great price.
JimmyMac is offline
Old 10-15-2015, 12:09 PM
  #844
Default offset
Originally Posted by EDWARD2003
At yesterday's IFMAR off road worlds I managed to have a quick chat with the designer of the R12. I asked him about when it will be released. He said "February or March" of next year. The production version might be slightly different to the prototype. However, the new wheels are going to be used.
so the new car will have a different offset? what will compatibility be like with the current r12 and the rest of the 1/12 world
xps800doo is offline
Old 12-09-2015, 09:32 PM
  #845
EDWARD2003's Avatar
No idea. I am guessing the offset would be normal to the rest of the world. Who knows?
EDWARD2003 is offline
Old 12-09-2015, 10:04 PM
  #846
EDWARD2003's Avatar
Default Damper Tube Modification
After seeing the photographs of the new side damper tube system for the R12. I decided to come up with something similar.
The only additional parts I used was a Tamiya 104 roll damper OP.1413 F104. You'll need 2 to complete the conversion.
In the photograph I only have one Tamiya tube installed.
What did I do to make it work?
I cut down the two aluminum posts off off R12-22. I cut them down and made sure they were flush with the center brace. This allowed the carbon fiber cross brace to be lower by approximately 2.5 mm. This allowed the damper tubes to function properly without making contact with the upper or lower plates. Next I flipped the carbon fiber cross around so the body posts holes on the carbon fiber cross brace are more forward. Original kit position has the body posts facing rearward. No changes were made to the upper plate.
The Tamiya damper tubes were fitted with BD7 ball cups on the plastic tube side and the Yokomo R12-37R with R12-19 on the aluminum tube side. You might have to cut your ball cups down in order for the damper tube to work accordingly.You will also need part number R12-03FN, R12-10LF, and some M2.5x6 mm screws and ball ends.
You will mount the aluminum tube side in the holes where the body posts are located. Take a long screw and thread the screw through the ball end. Make sure the "neck" of the ball end is touching the chassis. Then you take a "loose" ball (R12-19) and thread that down on top. This will act as a spacer between the ball cup and body post. This will allow the ball cup to move freely when you have mounted the body post. If you don't do this it will bind.
That's it.
Oh, since you've cut down the center aluminum brace you're going to have to readjust your side spring tension.... A lot. I run my side springs on the inner position, which is fine. I don't know if the outer (on top of side link) position will work after this modification.
Old 12-09-2015, 10:06 PM
  #847
EDWARD2003's Avatar
Photos of the damper tube from the rear.
See the extra pivot ball on top of the outer link?
I also had to ream out some material on the outer plastic cup to allow it to pivot freely.
Attached Thumbnails Yokomo R12-12308463_10101292740420441_1390639449766457447_n.jpg
Old 12-09-2015, 10:07 PM
  #848
EDWARD2003's Avatar
Front view.
As you can see there is a lot more clearance between the upper and lower plates. The black aluminum mount is from a Yokomo YRF-001.
The body posts are in a more forward position.
There are no contact issues with the rear bulkheads.
Attached Thumbnails Yokomo R12-12341327_10101292740365551_5921007090443874179_n.jpg
Old 12-10-2015, 07:18 AM
  #849
EDWARD2003's Avatar
Wink
Aluminum support cut down and sanded all by hand. Lol.
The Tamiya damper tubes are too large in diameter. I am going for the Team Associated 12R5.2 tube setup.
Old 12-11-2015, 07:19 AM
  #850
avs
avs's Avatar
if tube length is the issue, then:
Onpoint and CEFX use a compact damper tube. Mudslide is selling the onpoint tubes. They are similar diameter, but shorter to other current 1/12 cars.
avs is offline
Old 12-23-2015, 03:56 AM
  #851
EDWARD2003's Avatar
Hey, got the 1/12th with the Tamiya dampers to work. The car handled really well with the new tubes. Managed to qualify 3rd in the A-main.
On a side note I am in desperate need of part # R12-04N (Graphite lower pod plate). Most, if not all the online stores in Japan are out of stock. Yokomo has discontinued this part as well. That said, I was wondering if anyone knows of a place (in a hobby shop) in U.S.A or Europe that might have these in stock. I'm looking for several of them.
Any help would be much appreciated.
Thanks everyone.
Old 12-23-2015, 04:14 AM
  #852
IgorR's Avatar
Thanks everyone.
check there:
http://www.teamyokomo.eu/lower-brace...rld-conversion
IgorR is offline
Old 12-23-2015, 04:46 AM
  #853
Originally Posted by IgorR
Toni Sport has it in stock too...
http://www.fast-webshop.com/tonispor...rld-Conversion
Martin Paradis
P.S. Have you heard anything lately regarding the the new car?
rhodopsine is offline
Old 01-14-2016, 12:16 PM
  #854
time to let the r12 c3.1 down the road....
http://www.rctech.net/forum/r-c-item...rts-servo.html
Old 01-26-2016, 05:36 AM
  #855
On the latest car R12 C3.1 is there anything different how 1/12 rear wheels/tires bolt on and lineup from other manufacturers?
I know the yellow rim Yokomo ones are good and they are like the coolest looking. But how about everything else? CRC, Gravity RC, BSR, Ulti, Jaco, etc.
Considering the one for sale above.
190mph is offline
