Gear Mesh
Old 05-14-2004, 11:03 PM
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Gear Mesh
do you set gear mesh the same way on all cars or is there a difference between them?
i have a Yoke SD SSG and i don't wanna ruin my spur gear; i'm pretty green at this so any and all help is appreciated.
JayBee is offline
Old 05-15-2004, 01:12 AM
Timmy_G's Avatar
whats the problem you face? how much slack there is between the pinion and the spur gear?
Timmy_G is offline
Old 05-15-2004, 02:37 AM
burbs's Avatar
if u are new to gear mesh .. give this a try.. someone told me about this years ago...
take a thin pice of tissue or kleenex.. put it in between the spur and pinion.. push the gear tight to the spur,, but dont jam it tight,. just push it to it.. tighten the motor up,... then rol the gear and take out the kleenex... the gap it leaves should be right on
u will also find some spur gears are not perfectly round... so u may need to adjust it a little more...
basically u should be able to rock the spur back and forth and feel slight play in the mesh... i only run 64 pitch gears.. on sedans a cars.. it has been years since i wrecked a gear from mesh...as long as u get it right.. and keep the gear clean...
burbs is offline
Old 05-15-2004, 07:13 AM
That kleenix trick works for 48pitch though right? For 64 im guessing must be even thinner...
True R/C Racing is offline
Old 05-15-2004, 07:29 AM
lazyboy's Avatar
with 64 pitch i used a very thin piece of plasitc, like the plasitc seals on the gatoraide bottles with the twisty tops. it seems to work ok i guess, but i gave up on it since i check my mess by wiggling the gear to see if it has just a lil bit of play
lata lazy
lazyboy is offline
Old 05-15-2004, 07:37 AM
thats what i do, Move the Spur see how much play it has.
Old 05-15-2004, 07:45 AM
lazyboy's Avatar
yea it relitivly easy once u get the hang of it also. but as far as that new hpi car i got the motor mount is weird to me since i have been drivin a losi for the past year and a half lol
lazy
lazyboy is offline
Old 05-15-2004, 09:20 AM
JayBee's Avatar
Post
yeah i got the picture and it works pretty well. but also i can see how my spur and pinion mesh since i just built the car; and i just thought of something- the teeth of both makes a V inside of a V, so you want the V of the pinion 'halfway inside' the V of the spur. this way you get the 'play' that you want without the 'slop' that would tear the spur teeth up.
did that all make sense, cause my head is hurting- i'm going to take a tylenol
JayBee is offline
Old 05-15-2004, 09:22 AM
uhh, ....yea
Old 05-15-2004, 10:07 AM
all you need to do is allow a little bit of play betwwen gears.
rc_1uk is offline
Old 05-15-2004, 01:04 PM
RcMonk's Avatar
Here is another method. Set a tight mesh using a pinion that is one tooth higher than the one you intend to use. After that remove that pinion and swap it with the one that is one tooth lower and the mesh should be perfect.
RcMonk is offline
Old 05-15-2004, 02:27 PM
Tek Nickal's Avatar
Only works with 64p gears, I tried that.
Tek Nickal is offline
Old 05-15-2004, 03:47 PM
JayBee's Avatar
Post
i thought something didn't seem right with that method; sounded way too variable to me. thanks anyway, i think i'll stick with my method.
JayBee is offline
