Electric Motor Help >
Electric Motor Help
Electric Motor Help
Old 05-14-2004, 10:56 PM
g12314's Avatar
Default Electric Motor Help
Need some Help:
Just purchased a D5 motor for my TC3. Wired it all in, and the motor runs backwards. Uninstalled motor and put it on my Pulsar comp, to verify direction and it is indeed running backwards. Is it OK to run the motor with the POS and NEG wires switched around? Or did I get a defective motor?
Thanks in adavance for the help.
Jimmy
g12314 is offline
Old 05-14-2004, 11:04 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The end bell is probably on backwards. Loosen the two screws that hold the endbell on and rotate it 180 degrees around. Set the timing on it to about 20 degrees advanced and you'll be fine.
Jon Kerr is offline
Old 05-14-2004, 11:15 PM
yup the endbell is on backwards 180 degree turn is all it needs
R/C Anonymous is offline
Old 05-15-2004, 06:07 AM
g12314's Avatar
Thanks guys, that did the trick. I thought I rotated it 180 last night, but it looks like my brain was shut off (up too late I guess).
Thanks Again,
Jimmy
g12314 is offline
