Old 03-27-2002, 06:14 PM   #1
Default dean's plug question!!!
i'm trying to convert my stuff to dean's plugs, but i can't get the solder to stay on them it hardens then slides right off. i'v tried many types of solder and even bought a new solder iron! what is the problem???
rctc3 is offline   Reply With Quote
Old 03-27-2002, 06:16 PM   #2
CRASH's Avatar
Trader Rating: 26 (100%+)
It sounds like you are not geting the pug hot enough for the solder to flow. You are just melting the solder. You need to heat the tabs up more before you try to get the solder to flow on them.
CRASH is offline   Reply With Quote
Old 03-27-2002, 06:18 PM   #3
sp i should heat up the tabs, then m,elt the solder and put it ont there?
Old 03-27-2002, 06:26 PM   #4
CRASH's Avatar
Correct. The solder will melt before the tabs are actually hot enough for the solder to flow onto them. So just be patient when soldering them.
Old 03-28-2002, 08:57 AM   #5
Be careful not to let the tabs get too hot or they will melt through the plastic and then the plug will be useless. I lost count of how many I have melted
Modena AL is offline   Reply With Quote
Old 03-28-2002, 02:12 PM   #6
hah ya,i've done that i few times when i wasnt paying attention
Jarrod Langlois is offline   Reply With Quote
Old 03-30-2002, 09:38 PM   #7
jericsm's Avatar
found this in a magazine, i think, rcca, am not sure.... when soldering deans plugs, plug them together so the tabs will not move through the plastic.... hope that's clear.... a picture here would be great....
jericsm is offline   Reply With Quote
Old 03-30-2002, 10:21 PM   #8
that is a GREAT idea jericsm. You have just solved all my deans connector soldering problems. Thanks alot!
quick plug question blktransam Nitro Off-Road 36 07-18-2008 09:10 AM
plug amp draw question? nitrothugg Nitro On-Road 0 12-13-2005 03:40 PM
Glow plug question sc0rch Rookie Zone 1 06-04-2005 04:41 AM
Plug heat range question THE DOCTOR Onroad Nitro Engine Zone 5 04-25-2005 09:55 AM
question about glow plug RCdave Rookie Zone 3 03-23-2002 01:04 PM
