Tire warmer temperature >
Old 05-13-2004, 02:48 AM
FUK_WRX's Avatar
Default Tire warmer temperature
Guys this is a dumb question but im really unsure, i got a trinity digital tire warmers anyway was wondering what the ideal temperature used on Sorex 28R and Sorex 24R? Im scared i might over heat them.
Should it be aroun 30Deg or something?? Any help would be appreciated.
FUK_WRX is offline
Old 05-13-2004, 07:59 AM
AdR|aN's Avatar
Hiya fren.
Just a rule of thumb.
The tires temp. is always higher then the track surface temp.
I am using Tamiya tire warmer and it warms out to about 55 deg C.
IMHO.
You can start experimenting from 50 deg C.
AdR|aN is offline
Old 05-13-2004, 08:08 AM
WC
WC's Avatar
Trader Rating: 28 (100%+)
Next time you run your car a full pack at racepace, check the temp of the tyres immediately when it leaves the track. They can be pretty warm.
Then use your tyrewarmers to keep that same temp for start of your next run.
WC is offline
Old 05-13-2004, 09:28 AM
Tommy Bergfeldt's Avatar
I run my Trinitys at 55-65 C or more always, that's what i feel is the best temp
Tommy Bergfeldt is offline
Old 05-13-2004, 08:05 PM
FUK_WRX's Avatar
thanks for the response guys
FUK_WRX is offline
Old 05-13-2004, 08:56 PM
Thats about it!!!... prolly a bit warmer as they will loose some temp after you take them off.
Dragonfire is offline
Old 05-13-2004, 09:13 PM
VenomWorldOrder's Avatar
i like using wd 40 on the tires, then putting them in the warmers. mmmm soft
VenomWorldOrder is offline
Old 05-13-2004, 09:16 PM
WC
WC's Avatar
"Basted & Baked"... hmmm, smells like Chicken!
WC is offline
