Tamiya TB02 help >
Tamiya TB02 help
Tamiya TB02 help
Old 06-02-2010, 04:16 PM
Trader Rating: 53 (100%+)
Default Tamiya TB02 help
Im re-gearing my friends tb02 and tried to gear up a bit since we changed the motor. is the gears a 32 pitch on this car? Thanks for any help
NorCalLump is offline
Old 06-02-2010, 04:22 PM
cyclone x's Avatar
tamiya likes to use a metric pitch its about a 32 pitch if your gunna re gear just do all 64 pitch try a 100 tooth spur and depending on motor anywhere from a 45 to 30 tooth
cyclone x is offline
Old 06-02-2010, 04:24 PM
Waltrip55's Avatar
The car comes with metric 48 pitch. That is the only gear type you can use because the spur gear is slid onto the shaft.
Waltrip55 is offline
Old 06-02-2010, 04:32 PM
cyclone x's Avatar
yeah i ment to say 48 pitch sorry and you can convert if you get 3 racing upgrades. To save the hassle just buying 48 pitch gears is better
Old 06-02-2010, 05:40 PM
tried my rrp 23t 48p and just wont work. I tried using the guide they have to say what holes to mount motor in, and it doesnt mesh up with the spur gear...
Old 06-02-2010, 06:36 PM
cyclone x's Avatar
oh i think the biggest is just a 21 t
Old 06-02-2010, 06:44 PM
using a 23 pinion with the 55t spur. problem is, tamiya says to mount motor in slots "b". When I mount it that way, pinion barely touches spur. to get any contact, I have to use the 58t spur with the 23 pinion, but it whines like crazy!
Old 06-02-2010, 07:14 PM
ok, got it figured out. im stupid. I wasnt paying attention when youi kept saying metric pinions. didnt realize there was a metric 48 pitch
Old 06-04-2010, 10:07 AM
KREATOR1's Avatar
Try this chart
KREATOR1 is offline
Old 06-04-2010, 12:11 PM
Hebiki's Avatar
Trader Rating: 26 (100%+)
biggest pinion tamiya made was 28T. 3Racing made bigger pinions in the same pitch... but wont fit in the TB-02 because of the mounting holes.
Originally Posted by KREATOR1 View Post
Try this chart
good chart!
Hebiki is offline
Old 06-04-2010, 12:16 PM
thanks for all the help everyone
