Old 07-13-2011, 08:41 PM   #841
koopesv's Avatar
Trader Rating: 18 (95%+)
Has anyone ever tried to just pack the diff with grease?
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 07-21-2011, 01:31 AM   #842
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i dont think it's a good idea....
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-21-2011, 12:59 PM   #843
Who's managed to strip the little allen head screws yet? And how did you manage to get it out?
YZFAndy is offline   Reply With Quote
Old 07-21-2011, 01:50 PM   #844
I stripped one, but luckily felt it going before it was all the way in. I got it out with pliers on the screw head.
If I stripped one when it was all the way in, I'd probably try slotting the head with a dremel, and using a screwdriver. I've never actually done that successfully on anything, though, so if someone else has a suggestion, listen to them.
-Mike
Old 07-21-2011, 02:27 PM   #845
any chance of one for the Kyosho TF6 ????
sidecarphil1 is offline   Reply With Quote
Old 07-22-2011, 07:30 PM   #846
spring71's Avatar
Smile
Hello racers,
Spec-R gear diffs and parts are re-stocked at TQ RC RACING.
http://www.tqrcracing.com/shop/produ...t.asp?s_sort=4
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
[email protected]
spring71 is offline   Reply With Quote
Old 07-24-2011, 03:49 PM   #847
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Spec R fix the diff
Well after my son running the Spec-R gear diff in his Mi4-CX in mod for a few race meetings I have found that they are shit, the plastic gears can not hold up to the power that a 4.5 turn motor with boost and turbo can put to the ground, 4 drivers that were running the Spec-R diff on the weekend had them fail.
They either have the slot flog out were the pin sits or they just strip the side gear, 2 x 5min runs and thatís it, I can get a ball diff to do that.
Spec-R need to make some steel gears and fix the slop in cases were the out drives go in, on the Mi4 diff anyway, I checked a Tamiya diff and they did not wobble as much.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 07-24-2011, 03:59 PM   #848
koopesv's Avatar
Damn I havent seen a bad one yet, they leak yeah but then again I dont know many people that run 4.5 with boost. I love mine besides the leaks here and there. What oil are you guys using im between 1k-2k but thats just me but some run 800.
Urban Heat Racing
Old 07-24-2011, 04:14 PM   #849
GSM Storm's Avatar
Default Not happy
If you were at our track on the weekend you would have seen 4, We have tried a few oils, the best results have been with 1000 CST AE diff oil, mine leak bad from the out drives if I use the standard o ring, I have found by using a Agama shock o ring it did not leak on the weekend, but it only lasted two and a half runs before the gears went.
Regards
Gary
Driver Gazza
Old 07-24-2011, 04:22 PM   #850
koopesv's Avatar
Regards
Gary
Use good amount AE Green Slime and the new o rings helps slow down the leaks a lot.
Urban Heat Racing
Old 07-24-2011, 09:33 PM   #851
kschu's Avatar
Regards
Gary
i ran 4.5t with boost too and mine doesnt fail on me...need to shim properly and also use alittle thicker oil ..around 1k-2k...
put yokomo thick grease around the o-ring..it's can stop leaking for 1 race meeting and u need to service the ring and put in some grease again afterward.....
Old 07-25-2011, 12:58 PM   #852
Regards
Gary
They are not good, yeah, but IMO that's because of the leaking and the weight. I run boosted 4.5, and I have never had a broken diff. I have even run a nearly dry diff (all oil leaked from the diff) and still not broken.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 09-24-2011, 07:45 PM   #853
Trader Rating: 152 (100%+)
need help in building a front gear diff with cleaning putty
S I O is offline   Reply With Quote
Old 09-24-2011, 08:19 PM   #854
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi roll small sized balls of cleaning putty about 2-3mm in size push it in and around the gears with a 2mm driver but only use enough putty as you would oil and put about 5 drops of thin diff or shock oil and your ready to roll.:-)
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 09-25-2011, 04:18 AM   #855
From what I have seen a putty diff works best when you pack as much in as you can. Mix it with a very small amount of oil so the putty loses that "sticky" feeling.
I don't know how most people go with this diff but I saw quite a few fail at an event this weekend. Medium grip with 4.5t motors in most cases.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
