Old 07-05-2011, 06:24 PM   #826
Send a message via AIM to munrath
xrayaustin - You might want to try Green slim as it seems to help.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 07-05-2011, 06:31 PM   #827
Xpress's Avatar
Originally Posted by xrayaustin View Post
guys im running the gear diff in the rear of my mod t3'11 and am having alot of fun with it. gives alot more on power steering and i like it alot!
one problem i am having is it is throwing out oil, not excessively but it is enough to see oil on the chassis by the diff after a run. also due to this i am having to refill it with 2000 losi oil every 6-7 runs. is there anyway to keep the gear diff from leaking, and it appaears it is leaking out of the middle where the green gasket is. any ideas?
Go to an auto parts store and buy some gasket sealer that stays flexible...
Put a dab between your thumb and index finger and tap all the way around the gasket. Then install the gasket, fill, and assemble the diff.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 07-05-2011, 06:37 PM   #828
J.Filipow's Avatar
Trader Rating: 15 (100%+)
I highly recommend using Associated Green Slime (or similar) on not only the stamped, paper gasket, but also on the o-rings inside the gear diff housing. If your gear diff continues to leak, you'll simply need to replace the paper gasket and the o-rings (Spec-R made a running change to a 'double' o-ring), apply the Green Slime, and your problem will be solved. I've done the above and had a dramatic decrease in leaking. Good luck.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 07-05-2011, 09:32 PM   #829
TB03Racer09's Avatar
I want to get one for my tb03. the stock diff drives me mad, it has soft cap screws, crap thrust bearings, crap balls and the diff halves are destroyed.
Does it come with shims for each bearing so it meshes perfectly?
So do you think I should get it?
TB03Racer09 is offline   Reply With Quote
Old 07-06-2011, 05:36 AM   #830
Benzaah's Avatar
Trader Rating: 21 (96%+)
Originally Posted by grippgoat View Post
http://store.hkshobby.com/product_in...oducts_id=8856
I stripped a screw head, and all I had to replace it was extra Mi4 spur gear screws. It tightened down just fine, and that diff hasn't leaked a drop.
-Mike
That shop is great until you see the shipping price to australia. Its minimum $20us for 0.4 pounds of goods The search continues at least i know what im looking for now thanks guys.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 07-06-2011, 07:01 AM   #831
lochness42's Avatar
Do you have local Schumacher distributor there? If yes get screws from them (or get them order it for you) http://www.racing-cars.com/pp/Manufa...ec_R/G870.html
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 07-06-2011, 08:03 AM   #832
Benzaah's Avatar
They must have only been recently added or in a hard to find spot as i searched the schuie site only last weekend for those. Thanks.
Old 07-06-2011, 08:42 AM   #833
lochness42's Avatar
They were there before (at least on 10th May when I ordered mine) You most likely just missed it.
Pavel Balint
Old 07-06-2011, 05:05 PM   #834
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Spec-R diff parts
Hi Ben
Get your Spec-r diff parts from here, www.egrracing.com, great price and postage is cheap and quick.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 07-06-2011, 06:29 PM   #835
GSM Storm's Avatar
Default Oil Conversion Chart
Hi all
I am looking for a conversion chart or formula to cross reference oil that is rated at WT with oil the is rated at CST.
Regards
Gary
Driver Gazza
Old 07-06-2011, 11:15 PM   #836
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by GSM Storm View Post
Hi all
Regards
Gary
http://www.petitrc.com/reglages/OilChart.pdf
Old 07-06-2011, 11:50 PM   #837
Hrm. I just disassembled one of the diffs I got from Schumacher, and the screws were a slightly loose 1.5. The 1/16 didn't seat fully and slipped. The spare screws I got from hks linked above were also 1.5. I need to double-check the diffs I got from hks now.
You defintely need to be patient and careful the first time you put the screws in, though, because they're a very tight fit while they cut threads. I'd suggest screwing them in once before assembly so it's a bit easier.
-Mike
Old 07-07-2011, 12:24 AM   #838
Geberit's Avatar
How much oil should I put in for the rear diff? Like in a nitro diff?
http://www.youtube.com/watch?v=k1PfllEfx3A
or like in this video only a few ''drops''
Regards, Lojz
Geberit is offline   Reply With Quote
Old 07-10-2011, 03:16 PM   #839
GSM Storm's Avatar
Default Diff are no as good as they could be
Hi All
Has anyone had the slot in the side gear were the pin sits flog out, running mod there is too much torque going through the diff, the gears need to be made out of a stronger material.
Has anyone tried any steel gears to see if they fit in the diff housing, from a gas car or the new Serpent gear diff ?.
Regards
Gary
Driver Gazza
Old 07-13-2011, 08:16 PM   #840
does spec-r make a metal gear diff for the ff03? The small gears in my plastic one has blown and I've read some others have done the same. thx.
one-nil is offline   Reply With Quote
