Old 05-18-2011, 06:39 AM   #796
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Jochim_18 View Post
What modification Do I have to do for the BD5 gear diff to fit my TC6?
Do not use the shims for the bearings, if you do, it will be to tight and bind the bearings. You need to open the centers of the outdrive to accept the bone, a 1/4" drill bit works. Very lightly sand the blades to allow them to move freely in and out of the outdrive.
ira is offline   Reply With Quote
Old 05-25-2011, 06:06 AM   #797
I need info on this. I decide to get the diff for my Xray and put it together I didn't want to put in the car until I get to the track to see the difference with it compare to the ball diff had it sitting for about a week in the package it came in to find out the diff leak without using it, is this a common problem? and is there a fix for it? please anyone with info.
gofasteddy is offline   Reply With Quote
Old 05-25-2011, 10:57 AM   #798
defcone's Avatar
Trader Rating: 15 (100%+)
I used quite a bit of grease on the outdrive where it slots into the housing and on the o rings and that stopped the leaking until the grease got spun out or dissolved into the oil.
defcone is offline   Reply With Quote
Old 05-25-2011, 03:09 PM   #799
koopesv's Avatar
Trader Rating: 18 (95%+)
I have a few quick questions on Gear Diffs.
1 What are the benefits?
2 What is the benefits if used F/R
3 What is the benefit if the rear is gear diff and the front ball(and vise versa).
I have 2 Spec R diffs any help would be great.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 05-25-2011, 03:09 PM   #800
warnos's Avatar
mine did the same thing but was leaking around the pulley.. fixed it with some automotive silicone.. what defcone said works a treat on the outdrives..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 05-25-2011, 11:31 PM   #801
spring71's Avatar
Smile
To prevent the leaking, fill it up only 20% and use thicker oil like 20,000 diff fluid.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 05-25-2011, 11:31 PM   #802
spring71's Avatar
Smile
Spec-R Gear Diffs, C.V. Universals are in stock at TQ RC RACING.
Click Here to check out the Spec-R products.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 05-26-2011, 07:09 AM   #803
I will try the silicone.
Old 05-26-2011, 07:51 AM   #804
Default HB TCX
Hi
I have a almost not used Spec R diff for the Yokomo BD5 , but have now a HB TCX , does anyone know if I can only buy the case and re-use internal gears and out drives from the BD5 diff of do I have to buy a complete diff
Mike
HB-forever is offline   Reply With Quote
Old 06-04-2011, 12:27 AM   #805
spring71's Avatar
Smile
New items arrived from Spec-R and Tamiya.
Click Here to see the new arrivals.
Click Here to see the re-stocked items.
Thanks.
TQ RC RACING
Online Shop
[email protected]
Old 06-04-2011, 04:47 AM   #806
VooDooPH's Avatar
Send a message via Yahoo to VooDooPH
tried the specR DCJ's and an axle disintegrated at the axle after 2 packs... i even rebuilt the axle and packed the joint with AW grease. had the same happen to a friend although his lasted a bit longer (6-8 packs)...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 06-17-2011, 01:08 PM   #807
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
I've been using the Spec-R GearDiff for Xray T3 for the last month and have had zero problems. I followed the directions by lightly sanding the gears. I think the trick is not to make it perfect but get the gears flat so they run true. The diff will feel tight at first but after a couple easy laps, it will be perfect.
I also used Associated Green Slime on the o-rings. Also lightly sanded the edges of the diff cases where they come together to get them flat for solid contact.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-17-2011, 01:15 PM   #808
Dane's Avatar
Originally Posted by wallstreet View Post
whats the easiest way to clean a spec r gear diff so i can change the fluid inside ?
Pour the old oil into the trash, spray out the gears and housings with motor spray. Let dry. To be extra careful, it would be a good idea to disassemble it so to get all old oil/dirt out.
Old 06-26-2011, 02:37 PM   #809
Coming soon.......... from Spec-R
Team EGR Racing
www.rcatomic.com
www.spec-r.com
Atomic-USA is offline   Reply With Quote
Old 06-26-2011, 03:55 PM   #810
Xpress's Avatar
1 million cst? 3 million cst? What's in the container? Concrete?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
