Old 03-24-2011, 10:06 PM   #751
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by RC MARKET View Post
why don't like brushed motor & Ni-Mh battery ?
Basically the same reason why dont like ride horse to work!
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-25-2011, 08:11 AM   #752
spencehotbodies's Avatar
Default tcx gear diff
Hello
Hope some one can help ;0, I have a tamiya 417 gear diff I have been running in my tcx, works great, now there is a proper one out can the middle gear be changed so I don't have to buy the whole thing again?
spencehotbodies is offline   Reply With Quote
Old 04-05-2011, 12:07 PM   #753
TheCoolCanFanMan's Avatar
Originally Posted by Barry_Hughes View Post
Built my spec R for the TCX
It feels nice and smooth with 1000K oil, but one of the outdrives has about 1.5mm play by which I mean I can pull the outdrive outwards by this amount, th other side has very little movement.
Should I take it apart and add shims so there is no movement at all?
Hi Barry
Have you found that you had to change the setup from what you normally used with a ball diff, I found you have to keep on the power more into the corner.
Any chance you could pm me your setup please.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 04-06-2011, 10:15 AM   #754
bigz's Avatar
Originally Posted by TheCoolCanFanMan View Post
Hi Barry
Cheers Malc
+1
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 04-06-2011, 11:52 AM   #755
rosko's Avatar
I dont use the gaskets that come with the gear diff I just used gasket maker from autozone and my gear diff doesnt leak at all. When I tried using the gasket supplied with the diff the two pieces didnt completly seat together their was like an 1/2 mm gap
rosko is offline   Reply With Quote
Old 04-06-2011, 01:18 PM   #756
SlideMasteR's Avatar
any news on a geardiff for the schumacher's ???
Xray T4 15' - Hobbywing V3.1 ESC - Reedy Modified Motors - Thunder Power Batteries - Protoform - Much More
SlideMasteR is offline   Reply With Quote
Old 04-06-2011, 08:28 PM   #757
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
I just bought a new spec r diff for my 417 and I have a problem. It binds a little bit don't know if that's normal or does it have to smooth? And I did polish the gears as well.
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 04-06-2011, 09:15 PM   #758
Listed on their website under Speed Secret option parts, but still out of stock on their website. I've been checking daily.
-Mike
Old 04-06-2011, 09:17 PM   #759
kschu's Avatar
Send a message via MSN to kschu
u need to polish more under the gear ....
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-06-2011, 11:31 PM   #760
They need to be smooth. Use very fine sand paper. Sand the back of larger diff gears, then reassemble the diff and try again. Keep doing it until it is smooth. If it is not smooth will strip the gears easily. It will take sometime as it took me 45min last night just for this process.....
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 04-07-2011, 02:54 AM   #761
Ok so I polished the hell out of it and it got a loooooot better. But I still feel a little bit of the gear when going left to right or is that normal?
Old 04-07-2011, 01:41 PM   #762
Barry_Hughes's Avatar
Hi Barry
Cheers Malc
Hi Malc,
only run it in 3 heats so far.
Basically the set up is the same as my std set up, have gone to 1.5 degree FF block, car seemed ok.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 04-07-2011, 01:46 PM   #763
GMartinez's Avatar
Trader Rating: 85 (100%+)
I have not had any issues I used the 3m 300 fine grit to polish it Im using mine in the front with 300,000 on my 417
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-07-2011, 02:54 PM   #764
Hi Barry
Cheers Malc
Malc,
What oil are you using in the gear diff?
I tried it back to back with a ball diff and had more rear traction and slighly less steering but way more control of the power out of a bend.
I run 1K oil.
If you need any setup help just drop me a PM
Russ W
rc_jammer is offline   Reply With Quote
Old 04-07-2011, 09:48 PM   #765
yes, as there will be some play between the outdrive and the diff case. if you push the outdrive in and turn the diff you will feel the diff not really smooth. As long as it feel smooth if you just turn it "normally" it is ok.
